purplemoon99(at)bellsouth Guest
Posted: Thu Oct 04, 2007 6:15 pm Post subject: heavy left wing/roll to left |
All the input on the "Heavy Wing" has been great ,and I'am sure it 's been beat to death.As Columbo says "Just One More Thing" Does any one have a pict. of one on a plane? Is .025 thick enough ? About how long and how wide,and how much is is hanging off the wing? Pop rivited? I just want to get it right Thanks again to you all !! Joe N101HD 601XL/RAM
amyvega2005(at)earthlink. Guest
Posted: Fri Oct 05, 2007 6:40 am Post subject: heavy left wing/roll to left |
just put an aileron trim on it. Zeniht sells a great kit for it. most planes this size have a heavy wing situation, just trim it.
Afterfxllc(at)aol.com Guest
Posted: Fri Oct 05, 2007 7:12 am Post subject: heavy left wing/roll to left |
Before you rivet it to anything make a small tab and use aluminum tape to hold it in place then keep tweaking it untill you have the size and angle you need then rivet it on. It doesn't take a big tab try not to go overboard on your first try. Look at some rudder tabs and start there.
In a message dated 10/5/2007 10:42:32 AM Eastern Daylight Time, amyvega2005(at)earthlink.net writes:
| Quote: | All the input on the "Heavy Wing" has been great ,and I'am sure it 's been beat to death.As Columbo says "Just One More Thing" Does any one have a pict. of one on a plane? Is .025 thick enough ? About how long and how wide,and how much is is hanging off the wing? Pop rivited? I just want to get it right Thanks again to you all !! Joe N101HD 601XL/RAM
See what's new="_blank">Make AOL Your Homepage.
Posted: Fri Oct 05, 2007 8:26 am Post subject: heavy left wing/roll to left |
again, longer and narrower is usually better/more effective than shorter and wider. More tab area bent to a shallower angle is usually better/more effective than smaller tab bent to a greater angle.
Dave Downey
Harleysville (SE) PA
100 HP Corvair
Posted: Fri Oct 05, 2007 9:17 am Post subject: heavy left wing/roll to left |
We didn't have a heavy wing problem largely because we put the battery on the right side in front of the rear spar and probably the most helpful was off setting the main gear 2 feet to the right....... O no!!!!
In a message dated 10/5/2007 12:28:53 P.M. Eastern Daylight Time, planecrazydld(at)yahoo.com writes:
| Quote: | again, longer and narrower is usually better/more effective than shorter and wider. More tab area bent to a shallower angle is usually better/more effective than smaller tab bent to a greater angle.
Dave Downey
100 HP Corvair
rstone4(at)hot.rr.com Guest
Posted: Fri Oct 05, 2007 9:36 am Post subject: heavy left wing/roll to left |
Members,
When I had my ZodiacXL built I was sure that I would need wing trim so I ordered it to be installed. This aircraft is so small and light that just the pilot if he is a big guy will cause the left wing to be low. Also a pasenger who will be on the right side of the cg will sometimes cause the right wing to dip so the only way to insure that you fly level no matter heavy pasenger, or what ever, if you have a trim tab on one of the wings, this can be corrected. I would advise all builders to install wing trim so you have a way to adjust in flight.
Bob Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri Oct 05, 2007 7:37 pm Post subject: Re: heavy left wing/roll to left |
A couple of comments -
1.) Twist in the horizontal stabilizer can also contribute to a rolling tendency as will asymmetrical wings or any errors in rigging.
2.) Careful fuel management (to reduce weight in the heavy wing) and sticking some weight in the "light" wing's baggage compartment (if you have one) can be helpful as well. You'll get better overall performance if you don't have to crank in a lot of aileron trim.
The wing heaviness problem described on this forum is not unique to light aircraft like the XL. I had to add an aftermarket electric aileron trim to the left wing of my C182 (2950# gross). It had 40 gallons of fuel (240 lbs) in each wing when topped off and tended to "lean" as fuel was burned. Without the aileron trim the Cessna 300 Autopilot didn't have the strength to keep the wings level.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
barcusc(at)comcast.net Guest
Posted: Sat Oct 06, 2007 6:20 am Post subject: heavy left wing/roll to left |
I flew with Bob in his plane a few weeks ago, he trimmed it up to the point it was stable hands off. That was the third 601XL I have flown in, one of them had no trim and it was uncomfortable to fly. Personally, I wouldn't build one without the Zenith electric trim, in my opinion, it is well worth it.
Clyde Barcus
601 XL, Continental Powered
Wings, Tail & Engine Complete
Working on Fuselage
Posted: Sat Oct 06, 2007 3:47 pm Post subject: heavy left wing/roll to left |
Hay Clyde,
Thanks for the vote of confidence.
Bob Yes, I am lurking somewhere on the net all the time.
