IVO prop blades for sale
akflyer
PostPosted: Fri Oct 05, 2007 8:08 am    Post subject: IVO prop blades for sale Reply with quote
I have 3 matched blades, 68" high pitch ultralight for sale. The have around 25 hours on them. save 50% off factory. 200 plus shipping (25 to 30 bucks)
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
jdmcbean(at)kitfoxaircraf
PostPosted: Fri Oct 05, 2007 11:01 am    Post subject: IVO prop blades for sale Reply with quote
They are not the correct blades.. the prop rotation is different....
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
kcozik(at)cablespeed.com
PostPosted: Fri Oct 05, 2007 11:40 am    Post subject: IVO prop blades for sale Reply with quote
I have 2 matched sets also.(3 blade) They are magnum blades for 9xx series (right
hand). Not sure what the hub cost is but they will work with an inflight of ground
adjust. 67"or 68".
Kevin Cozik
Lansing MI
series 6-7
914 turbo
czech amphibs
clint_bazzill(at)hotmail.
PostPosted: Fri Oct 05, 2007 7:15 pm    Post subject: IVO prop blades for sale Reply with quote
If you use the UL blades on 912ULS they should be 72 inches.
I had 68 inch on 912ULS and they were a little short.
Clint 912ULS 1260 hours
[quote] From: jdmcbean(at)kitfoxaircraft.com
Subject: RE: IVO prop blades for sale
Date: Fri, 5 Oct 2007 13:01:06 -0600
--> Kitfox-List message posted by: "jdmcbean" <jdmcbean(at)kitfoxaircraft.com>
Fly Safe !!
John & Debra McBean
208.337.5111
7suds(at)Chartermi.net
PostPosted: Tue Oct 09, 2007 6:45 pm    Post subject: IVO prop blades for sale Reply with quote
Clint and John,
Thank you for your replies on the prop, that end of my project has been stalled looking for a prop, I purchased a GSC from another 912ul Kitfox upgrade but the hub did not fit my engine. I have attached a pic of my engine hub, bolt circle approx 4", bolt holes are for 5/16 bolts, bolt hole bosses are .510 OD and center boss 1.850 OD. Can anyone tell me what I need to fit this??
Lloyd Cudnohufsky
Model 5 912ul Rebuild
Northern Mi.
 Filesize:  312.35 KB
 Viewed:  578 Time(s)
Sjklerks(at)aol.com
PostPosted: Tue Oct 09, 2007 7:02 pm    Post subject: IVO prop blades for sale Reply with quote
Hi Lloyd, What year is the engine? Rotax changed the bolt pattern after 1995 I believe.
Jim Klerks
Model IV-912
eskflyer
PostPosted: Tue Oct 09, 2007 8:58 pm    Post subject: Re: IVO prop blades for sale Reply with quote
DAM guys change the darn subject if your going to ruin ones thread or start your own . when we go into these things to look it is nice to be able to follow a post and not with BS.
THE BLADES ARE SOLD BY THE WAY FOR THE IVO IFA .
FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus
