CHETKRU(at)aol.com Guest
Posted: Thu Oct 04, 2007 3:52 pm Post subject: Canopy Crack....... |
Hi Folks, looking for a solution to repair a hairline crack in my canopy, it is not in a line of sight area and if the repair is not clear it will not be a problem, I just want to seal the break and keep it from growing. I have already stop drilled the area. Any thoughts or tips will be greatly appreciated, such as brands of epoxy or glue that might work.
Chet Kruleski
601XL
Las Vegas, NV
See whatarget="_blank">Make AOL Your Homepage.
Afterfxllc(at)aol.com Guest
Posted: Thu Oct 04, 2007 5:21 pm Post subject: Canopy Crack....... |
Go to your plastics supply company... they make a solvent that will bond the crack I forgot the name of it but I'm sure if you tell them what you are needing they will help you out.
t_fogelson(at)yahoo.com Guest
Posted: Thu Oct 04, 2007 7:13 pm Post subject: Canopy Crack....... |
What we did in our helicopters when they would develop
a crack was to stop drill at both ends and then glue a
piece overtop the cracked area.
Terry
--- CHETKRU(at)aol.com wrote:
| Quote: | Hi Folks, looking for a solution to repair a
will be greatly
might work.
Chet Kruleski
601XL
Las Vegas, NV
Don't let your dream ride pass you by. Make it a reality with Yahoo! Autos.
http://autos.yahoo.com/index.html
xl(at)prosody.org Guest
Posted: Thu Oct 04, 2007 9:25 pm Post subject: Canopy Crack....... |
That's what I did on 633Z.
See: http://www.cleanh2o.com/633z/seattle_looking_south.jpg
I barely got the crack stop drilled in time to avoid a 2 piece canopy.
I took the canopy to a plastics shop and was told that the crack could
not be repaired - seems like it depends on who you talk to. So I glued
plastic over it. Fortunately, the crack is easy to forget in flight.
It's been that way since 2003.
I caused the additional hairline cracks by clamping the patch between
plywood scraps while it was drying. Turns out that is a bad thing to do.
The canopy has complex curves and is stressed. Don't clamp it and force
it flat. I used 'Craftics #33' glue, for acrylic, lucite + plexiglas.
The glue did cause the patch to become opaque. Not a problem in my
application. But not what I wanted either.
Joe E (at) BFI
On Thu, 4 Oct 2007, Terry Fogelson wrote:
Terry
> will be greatly
> might work.
> Chet Kruleski
> 601XL
> Las Vegas, NV
> do not archive
bryanmmartin
Posted: Fri Oct 05, 2007 1:11 pm Post subject: Canopy Crack....... |
I had a couple of small cracks on mine. I obtained some methylene chloride and put some in a syringe and squirted it directly into the crack. I t will wick into the crack and weld it shut. You have to wipe up any excess immediately or it will fog the surface. Use in a well ventilated area and try not to get any on your skin.
Methylene chloride is the main ingredient of most acrylic adhesives. A watery liquid adhesive is best for repairing cracks. There's some available here halfway down the page:
http://www.wingsandwheels.com/page37.htm
You might be able to find it at hardware stores or hobby shops also.
On Oct 4, 2007, at 7:50 PM, CHETKRU(at)aol.com (CHETKRU(at)aol.com) wrote:
| Quote: | Hi Folks, looking for a solution to repair a hairline crack in my canopy, it is not in a line of sight area and if the repair is not clear it will not be a problem, I just want to seal the break and keep it from growing. I have already stop drilled the area. Any thoughts or tips will be greatly appreciated, such as brands of epoxy or glue that might work.
Chet Kruleski
601XL
Las Vegas, NV
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Fri Oct 05, 2007 3:02 pm Post subject: Canopy Crack....... |
Hi Bryan, Thanks for the information, I will check it out as soon as I am finished computing.
Cheers,
Chet Kruleski
See what's new="_blank">Make AOL Your Homepage.
shilcom
Posted: Fri Oct 05, 2007 5:27 pm Post subject: Canopy Crack....... |
I used JB weld on a c-150 11 years ago and still ok. Bob U.
