		vwbugin(at)sbcglobal.net Guest
				 Posted: Thu Oct 04, 2007 9:43 am    Post subject: Jim's Rocket |
				Jim,
   On your #6 cylinder you might want to make a very close inspection of the line and fittings coming out of the flow divider going to the injector. I had a situation just like you and after many flights trying to clean the injector, looking for fod in the flow divider, etc. I discovered the stainless steel line from the flow divider to the injector had a very small hole in it. Since the fuel coming out of the flow divider is not under any pressure I didn't have any of the usual signs of a leak. But the crack was enough to allow air in the system which caused that injector to be lean. I would swap the line with another line and see if the problem follows the line. I was able to find the defect in my line but it took a magnifying glass to do it. The defect was located at the joint where the end is braised on.
   Steve
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		jrstone(at)insightbb.com Guest
				 Posted: Thu Oct 04, 2007 5:36 pm    Post subject: Jim's Rocket |
				Good one Steve,
  I'll take a look.
  Jim Stone
  [quote]   ---
