armywrights(at)adelphia.n Guest
Posted: Fri Feb 17, 2006 8:17 pm Post subject: glassing |
I have no foam rib material left over for the emp tip fairings. Is there a something available locally that will work as the backing for glassing in the backside of the tips?
Rob #392
Emp attach
schmoboy(at)cox.net Guest
Posted: Fri Feb 17, 2006 8:45 pm Post subject: glassing |
I just went to a Hobby or Craft store locally. They usually have plenty
of foam choices in various thicknesses.
-Sean #40303
Robert G. Wright wrote:
Rob #392
Emp attach
dmasys(at)cox.net Guest
Posted: Sat Feb 18, 2006 3:55 pm Post subject: glassing |
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: 2006/02/17 Fri PM 08:16:53 PST
| Quote: | I have no foam rib material left over for the emp tip fairings. Is there a
I got some 2 inch thick x 24 inch square foam from a local fabric shop and cut the outline of the tip ribs using a bandsaw. Then used the bandsaw to slice it in two so the foam was 1 inch thick (see picture at http://132.239.155.44/rv7a/tipfoam.jpg ). Worked well, particularly for the compound curve that is required on the HS tips. Glassed one layer of cloth over the foam, with a 1/8 inch flexible piece of wood wedged between the fairing and the elevator to keep a gap between them. Then removed the foam, added addition layers of cloth, and then used microballoon mixture to fill in the uneven areas on the fairing. Came out pretty well.
-Dan Masys
#40448
