aquamaster floats ???
akflyer
PostPosted: Thu Sep 27, 2007 12:29 pm    Post subject: aquamaster floats ??? Reply with quote
I buddy just called and asked if I knew anything about aquamaster floats. He said the guy he got them from said they were for a Kitfox. My buddy just picked up a KF mod I from a guy in CA and is having it shipped up here. I did a quick google searched and cant find anything on these floats.
If anyone has any info on them please let me know. This set is 12' long. I am looking for buoyancy info if at all possible.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
akflyer
PostPosted: Fri Sep 28, 2007 1:34 pm    Post subject: Re: aquamaster floats ??? Reply with quote
here are a few pics of the floats.. I have never seen them before..
 Filesize:  126.09 KB
 Viewed:  591 Time(s)
 Filesize:  235.63 KB
 Viewed:  556 Time(s)
 Filesize:  192.83 KB
 Viewed:  581 Time(s)
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Sat Sep 29, 2007 8:52 am    Post subject: aquamaster floats ??? Reply with quote
With that tunnel design I can see where they may be very efficient. I would
like to try a set before purchasing though. Like tunnel boats they may not
be able to take too rough water but on reasonably calm water I can see how
you could be off very fast. On rougher water they could transmit a lot of
pounding to the airframe.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Sat Sep 29, 2007 9:36 am    Post subject: Re: aquamaster floats ??? Reply with quote
my thoughts exactly... They are only 12' long, but look to be pretty wide so hopefully they will have enough buoyancy..I will carefully fill them with water and measure it out so I can figure out displacement.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Sat Sep 29, 2007 11:13 am    Post subject: aquamaster floats ??? Reply with quote
Bum a set of scales form a transport co. for an hour or two... Or even
weigh scales on the highway.
Weigh a float or a float on a trailer empty then fill to the "appropriate
level" of water and weigh again. The difference in the weight will be your
displacement. Around here the portable scales the highways department
carries for highway spot checks are more than accurate enough to read your
displacement within three or four pounds. Weighing a float can break up a
day for the inspectors.... Remember to pump the water out before carrying on
the highway though.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Guy Buchanan
PostPosted: Sun Sep 30, 2007 8:17 am    Post subject: aquamaster floats ??? Reply with quote
Anyone can see those floats are heavy. Just look at the tires on that
pickup! Wink
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
