VHMUM(at)bigpond.com Guest
Posted: Sun Sep 23, 2007 12:37 pm Post subject: spinner |
With the spinner instalation are people turning the prop to make sure the spinner is true? Just wondering as the engine is preserved and did not want to turn?
regards Chris
Dave(at)AirCraftersLLC.co Guest
Posted: Sun Sep 23, 2007 4:15 pm Post subject: spinner |
Chris,
You won't "de-preserve" it by turning the prop through by hand. Take the top plugs out so it's easier, and put a pointer at the tip of the spinner to check how true it turns. You will displace the spinner a bit when turning the prop, but if you kind of average it out the fit is just fine.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough
Sent: Sunday, September 23, 2007 1:34 PM
Subject: RV10-List: spinner
regards Chris
scottmschmidt(at)yahoo.co Guest
Posted: Mon Sep 24, 2007 6:37 am Post subject: spinner |
I just pushed it on, drilled the holes and it came out perfect. As long as it is even on the inside of the spinner it should be fine.
I never turned the engine to check it.
Scott Schmidt
scottmschmidt(at)yahoo.com
