chenoweth(at)gwi.net Guest
Posted: Mon Sep 17, 2007 4:29 pm Post subject: pitot |
As you know there isn't much guidance on the routing path for the line from the Pitot tube to the airspeed indicator. I'm following the drawing which calls for 1/4 aluminum tubing thru the wing. After that it seems to be every man for himself so I'll connect the aluminum to the nylon line once inside the fuselage by way of hose clamps and a piece of flexible tubing (Van's suggestion). But I'm looking for ideas about the routing and point of junction from wing to fuselage and then to the gauge. I'm trying to be sure I don't interfere with wing bolt insertion, control columns and pushrods, and other wiring. Plus trying to imagine how to connect all this together as the wing is joined to the fuselage.
Any and all suggestions will be much appreciated.
Bill
Albion, Maine
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
