ron.mcgann(at)baesystems. Guest
Posted: Mon Sep 17, 2007 3:09 am Post subject: Oil Canning |
Hey all,
Getting to the final assembly stage. I pulled out the VS that was completed over 3 years ago. Did not know any better at the time and thought my first airplane part was just fine. But there is significant oil canning on both of the large aft-lower panels. The only other oil canning I have is very minor on one or two of the lower wing skin panels, so the VS is really giving me the irrits. Any clues on how to tighten the skins?
cheers,
Ron
187 finishing [quote][b]
Posted: Tue Sep 18, 2007 3:00 pm Post subject: Oil Canning |
Zero responses. Searched the RV-10 archives and there is very little there. I guess I can only assume that no other RV-10 builder has any oil canning. The general RV archives are only a little more enlightening.
What happened to the good old days - when a basic building query met with half a dozen or more immediate useful suggestions? I hope the list has not not exhausted itself as a resource for builder assistance.
I know oil canning is common on all metal aircraft, but I am interested in solutions that the -10 crowd may have deployed to reduce or eliminate the problem - unless of course I am the ONLY crappy builder with oil canning.
cheers,
Ron
187 finishing
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Monday, 17 September 2007 8:38 PM
Subject: Oil Canning
Hey all,
cheers,
Ron
187 finishing | Quote: |
| [b]
Jack.Phillips(at)cardinal Guest
Posted: Tue Sep 18, 2007 3:09 pm Post subject: Oil Canning |
No, you're not the only one. When I mounted my horizontal stabilizer on the tail cone I found a couple of areas that weren't as tight as the rest. I've been watching to see what response you get.
Jack Phillips
#40610
Sent: Tuesday, September 18, 2007 7:00 PM
Subject: RE: Oil Canning
cheers,
Ron
187 finishing
[quote] From: owner-rv10-list-server(at)matronics Ecom [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Hey all,
cheers,
Ron
p://www.matronics.com/Navigator?RV10-List
ics.com
_________________________________________________
This message is for the designated recipient only and may contain privileged, proprietary
or otherwise private information. If you have received it in error, please notify the sender
immediately and delete the original. Any other use of the email by you is prohibited.
Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese
DAVELEIKAM(at)wi.rr.com Guest
Posted: Tue Sep 18, 2007 3:52 pm Post subject: Oil Canning |
I have an area on one elevator with a lose skin. I went to see my tech counselors RV-6 and he had a few of the same in different sections. He said it happens and if it is not dramatic, not to worry. Sorry, I can't offer more info.
Dave Leikam
40496
Wing guts
jeff(at)westcottpress.com Guest
Posted: Tue Sep 18, 2007 4:02 pm Post subject: Oil Canning |
Hi Ron,
I've got quite a bit of oil canning in my elevators. My tech counselor shrugged and said don't worry about it... but I'm not happy with it and may re do those parts if I've got some time to kill while waiting on panel parts.
I showed it to a cousin of mine who's done repair work on Airforce 1. He suggested drilling a hole in the middle of it, dimpling and flush riveting the hole.
I've not tried it... can't tell you if it works... but if you do, and it does... please let me know.
Jeff Carpenter
40304
N410CF
On Sep 18, 2007, at 3:59 PM, McGANN, Ron wrote:
[quote] Zero responses. Searched the RV-10 archives and there is very little there. I guess I can only assume that no other RV-10 builder has any oil canning. The general RV archives are only a little more enlightening.
cheers,
Ron
187 finishing
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of McGANN, Ron
Hey all,
cheers,
Ron
187 finishing
| [b]
EFDsteve(at)aol.com Guest
Posted: Tue Sep 18, 2007 4:20 pm Post subject: Oil Canning |
Dan Checkoway has something on his RV-7 site about this. He just used some RTV to attach some pieces of "J" channel to the inside of the tailcone, between the ribs to stiffen the skins. His entry on this is Sept. 2, 2005.
Steve Weinstock
40230
In a message dated 9/18/2007 6:12:04 P.M. Central Daylight Time, Jack.Phillips(at)cardinalhealth.com writes:
| Quote: | No, you're not the only one. When I mounted my horizontal stabilizer on the tail cone I found a couple of areas that weren't as tight as the rest. I've been watching to see what response you get.
Jack Phillips
#40610
cheers,
Ron
187 finishing
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Hey all,
cheers,
Ron
187 finishing |
See what's new="_blank">Make AOL Your Homepage.
DLIUDVINAITIS(at)aol.com Guest
Posted: Tue Sep 18, 2007 6:08 pm Post subject: Oil Canning |
Ron,
I myself have not had any signs of oil canning. Have done my Hs, wings, Vs, tailcone 1.5 years ago still have not seen any. Maybe when you were assembling Hs, wings, Vs, etc. you started at the ends and worked riveting inward towards centers. I myself started in center of assembles and worked outward this I thought would help by letting metal shrink/strech outwards towards the ends of assembles. worked for me I have no oil canning visible as for solving problem. shrinking metal/streching I would go with tech recommendations an/or move on and keep building.
Dave Liudvinaitis
#40466
fuselage, side skins
Posted: Tue Sep 18, 2007 6:43 pm Post subject: Oil Canning |
Thanks all for the responses.
As mentioned, I am at the stages of final assembly and the vast majority of panels are tighter than a drum. I religiously started riveting from the centre and worked towards the edges - as you have done Dave. On perhaps a handful of panels, the skin is not quite so tight and exhibits a slight 'wobble' when pressed in just the right spot, but the skin always recovers to the relaxed condition. The VS is just way too loose in my mind and needs to be tightened. I have heard other descriptions of oil canning as the skin popping out when pressed in a particular place - and staying there until pressed again. Am I confusing some flex in the panels with something more insidious?
cheers,
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLIUDVINAITIS(at)aol.com
Sent: Wednesday, 19 September 2007 11:37 AM
Subject: Re: Oil Canning
Ron,
Dave Liudvinaitis
#40466
| [b]
Tim Olson
Posted: Tue Sep 18, 2007 7:13 pm Post subject: Oil Canning |
Well, when there's so much stress that it goes "pop pop" as you
press and release, where it makes a concave and then when you
push opposite, it "pops" loudly out, then I'd think it might
be worth doing something about. The skin will have areas
where it will flex some though, and although I'm not addressing
any known engineering things on this plane or any other, I'm guessing
that you don't want it always stretched super tight, as wings and
surfaces need to flex. Maybe John can comment a bit. If you do
have a section oil canning, and it can't be easily fixed by some
riveting, it may be time for taking one of a few measures. I've heard
of stiffners either being riveted in or prosealed in. The access area
around my stall warning plate got oil-canning like that. I added
stiffners in that particular area around the hole...2 of them, one
in each direction. That took care of it. But, I'm cautious to offer
that as general advice, because I'm sure there are some areas where
adding stiffners might make things too...well...stiff.
I'm not sure that the list can give a definite answer on it, and it's
something that either might be best referred to a tech counselor
locally, or played by "ear" (with the popping noise). That's probably
why you didn't get quick answers....most people are just waiting to
hear what someone has to say, because the exact magnitude isn't known
without standing there by it.
Sorry, I know that didn't help, but it was a shot.
McGANN, Ron wrote:
| Quote: | Thanks all for the responses.
cheers,
Ron
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*DLIUDVINAITIS(at)aol.com
*Sent:* Wednesday, 19 September 2007 11:37 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Oil Canning
Ron,
Dave Liudvinaitis
#40466
acs(at)acspropeller.com.a Guest
Posted: Wed Sep 19, 2007 12:10 am Post subject: Oil Canning |
Ron, I had a similar problem with the VS but it occurred whilst I was adjusting nose ribs for a better fit (previous well known issue) and I was introducing a twist whilst trying to tighten the skin. Relaxed the shape and allowed the natural form to dictate the lay up without putting too much pressure on the fit. The skin should “suck” into the airflow in any case and unless it drums should not be an issue.
Otherwise you could always shove in a packet of self-expanding packaging foam!
John 40315
Do not archive and I in no way endorse inflatable RV-10’s
Sent: Wednesday, 19 September 2007 12:41 PM
cheers,
Ron
Ron,
Dave Liudvinaitis
#40466
<![if !supportLineBreakNewLine]> <![endif]>
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | - The RV10-List Email Forum - | 0123456789
AV8ORJWC
Posted: Thu Sep 20, 2007 6:33 pm Post subject: Oil Canning |
Last night at work (2AM local), I asked the former VANS Quality Control Inspector his opinion on your dilemma. “The kit is so well formed that few compound curves exist. The exterior skin should lay (naturally and *tight*) against the underlying framing structure - everywhere.”
Yes, you can use Draw Clecos but he says they were rarely needed. Most often it is the flanges not being bent or fluted consistently to the correct angle so they cause either a dimple or pimple to act on the skin. A few of the symmetric parts such as bulkheads have a left and right side which could contribute to a need for modifying the flanges. Occasionally they would see a hurried rigging and lay-up early on the build process before the manufacturer fully understood the technique. Most of the Horizontal and Wing are constant rib design to help reduce such a problem.
On the RV-10 several differing competitive teams (A-B-C-D) to build subsections (Empennage – Fuselage – FWF – Canopy) which could occasionally cause fitment dissimilarity. We builders tend to think if it as one big parts team. The use of shim stock or tapered shims could correct some miss alignment issues (which I have seen on a few inspections). Usually the builder accepts the occasional pimple (outty) or dimple (inny) as being a simple rock in the road to completion. There were a series of bad parts (not VANS phrase) on the RV-9 but the RV-10 has been pretty solid in the parts fabrication area. (Not to take away from what John Hilger and others ran into with cracked parts). As I understand it, the QC Department is now closed there. I guess they have reached perfection
We are often using 0.070 or 0.090 skin at work and several layers “webs” (it’s a pressure vessel) and the skin must be in full contact with the underlying semi-monoque framing everywhere before wet riveting. When replacing panels, we use Lexan for a template and black fine tip markers to get the edges within 0.001 of the original skin. It often stretches upon removal – hence the pulling of a template.
He said more attention to flange “finish” angle and the consequence of “Springback” when they formed the part originally will help. Fluting pliers is another tool. I am attaching pdf’s of what draw clecos look like. In a production environment, we use a pneumatic draw cleco tool to speed the process of installation and removal of the clecos.
Again oil canning is rare, is usually seen on assemblies completed early in the RV-10 build – and is rare but you are certainly not alone. Proper preparation of each framing member will reduce the likelihood. Some parts needed grinding on the curved flanges because they caused a projecting “hard point”.
Drilling it and pulling it “in” might be a USAF Air Force One thing cause they are not Certificated aircraft or OBAM built aircraft (they are Bureau built). Naval aviators would just slap Okum on it – like the expanding foam idea. I don’t know what Army Air Corp guys would do, they started in balloons didn’t they?
Questions and Responses are what make this build so great.
John
600
Do not Archive
Sent: Tuesday, September 18, 2007 4:00 PM
cheers,
Ron
187 finishing
Hey all,
cheers,
Ron
187 finishing | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | |
Hexnut_Draw_Cleco.pdf |
46.64 KB |
444 Time(s) |
Draw_Cleco.pdf |
18.66 KB |
434 Time(s) |
AV8ORJWC
Posted: Sat Sep 22, 2007 8:17 am Post subject: Oil Canning |
Oil Canning
A moderate deformation or buckling of sheet material, particularly common with flat sheet metal surfaces. Typically caused by uneven stresses at the fastening points. This terminology also refers to the popping sound made when pressure is applied to the deformed sheet forcing the deformation in the opposite direction.
Oil canning can be defined as the actual waviness in the flat areas of roofing and siding panels. Generally the period and amplitude of the wave depend on the continuous width of the flat.
Oil canning is an inherent part of light gauge cold formed metal products, particularly those with broad flat areas. Profiles having wide flat surfaces are often referred to as "architectural" roofing and siding panels. Such panels are distinguished from corrugated shapes as the latter are more fluted in design, have much narrower flats, and are less likely to exhibit oil canning.
Background
Oil canning has a number of causes:
1. Metal coil
Residual stresses induced during coil production can contribute. Examples of other contributing features are:
a. Full center - the coil is longer in the middle of the strip; this is the most common example. (The gradation manifests as ripples or buckles near mid-coil.)
b. Wavy edge - the coil is longer on the edge of the strip.
c. Camber - the deviation of a side edge from a straight line. (This is not always a problem.)
These conditions exist to some extent in all metal and tend to become more exaggerated as the strength level of the rolled sheet product increases and also for thinner and wider sheet product. When excessive, each circumstance may cause oil canning after roll forming by the manufacturer.
2. Fabrication
a. Slitting - The slitting of a master coil can release and redistribute residual forces. The coil's esponse can create or increase oil canning. The economics of rolling and coating wider coils makes slitting almost mandatory.
b.Forming - New residual stresses can be created during some forming operations. Architectural panel profiles typically require more forming along sides than in the middle, and often require more forming along one side than the other. This dictates that forming commences along the sides. This sequential "working" of the sheet will have a tendency to "trap" uneven metal contained within the coil in the panel central areas (corrugated ribbed profiles are most often worked from the center out, thereby "pushing" the uneven metal to the edges).
3. Installation
a. Misalignment of the support system - Structural supports that are produced, fabricated and installed within allowable tolerances can create a "non-planar" or contoured bearing surface. Stresses induced while panels conform to this surface can contribute to oil canning.
b. Over engagement of panels - Most panels accommodate transverse thermal expansion by flexing of webs and by "take up" at side joints. When panels are over engaged, these relief features are hindered or eliminated. In the extreme the "over engagement" process itself can generate waviness. Either cause can contribute to oil canning.
c. Over driving of fasteners - This operation creates stresses in the panel and provides a "reading line" at the fasteners.
d. Longitudinal Expansion - The surface temperature of exposed panels cycles throughout the year and even fluctuates daily. The temperature and the cycle depend on many variables, e.g. project location and orientation, cloud cover, panel inclination, surface finish or color, system thermal insulation characteristics. The panels' physical response is to expand or contract. If panels are restrained by "thru-fasteners", clips, or perimeter details, they try to accommodate or relieve thermal forces through several mechanisms, i.e. "slotting" around fasteners, out-of plane "bowing", local distortion of flat areas - "waviness". The magnitude of thermal force depends on the restraint provided (hence the panel stiffness and support stiffness), on the base materials' physical properties, and on the temperature differential between the support structure and the external skin. Waviness can be amplified when there is uneven fastener restraint along the panel. Such restraint is common on "concealed fastener" systems having fasteners along one edge and an interlock along the other. Waviness caused by thermal forces differs from other forms of oil canning in that waves can appear and disappear as the sun rises and moves around the building.
e. Movement of the primary structure - Excessive differential deflection, racking, drift, or settlement within the primary structure can cause noticeable waviness within panel flats. This distortion can be temporary or sustained.
f. Handling - Carrying of panels in the flat or twisting of panels can induce a wavy appearance to a previously flat panel. Twisting can occur if one corner of a panel is used to lift a panel or to remove the panel from a bundle.
Coil producers and panel manufacturers attempt to minimize these conditions and produce quality products. On going research seeks improved production methods. All of the above factors can and do occur and can cause oil canning in architectural roofing or siding products. While a number of factors dictate the panel design, the following are items that the designer, panel manufacturer, and erector may consider in reducing the occurrence of oil canning:
1. Coil:
Tension or stretcher leveling, a process whereby the metal is "stretched" in coil form beyond its yield point, will provide a flatter surface less prone to oil canning. In general the heavier the gauge the less likely a product is to oil can. The possibility of oil canning can be reduced by ordering tension leveled and re-squared material.
2. Design:
The addition of stiffening beads "breaks-up" the flat surface and makes oil canning less apparent. Embossing will also help hide surface waviness in the metal. The selection of lower gloss coatings and lighter colors tend to minimize the visual effect of oil canning.
3. Installation:
More stringent specifications regarding the alignment of the supporting structure will focus attention on this critical aspect. Instructions to the erection forces regarding proper handling, spacing, and fastening should be a part of the manufacturers' delivery packet.
Conclusion
Oil canning is an aesthetic problem. Normally structural integrity is not affected. However, structural integrity must be reviewed if the distortion results from an extreme external influence. Since many uncontrollable factors are involved, no manufacturer can realistically assure the total elimination of oil canning. With careful attention to the production and selection of material, to the panel design, and to installation practice, oil canning can be effectively minimized.
Unless specified tolerances have been accepted by the panel provider and panel manufacturer and are incorporated into the contract documents prior to fabrication, and if reasonable precautions have been taken, oil canning is not grounds for panel rejection.
John Cox
#600
