papadaddyo(at)tampabay.rr Guest
Posted: Sat Sep 15, 2007 6:44 pm Post subject: Questions |
I sent this yesterday but may have had the wrong to address. If it is a duplicate, I apologize. I am just about ready to close up the top skin on the tail. Is there anything that anyone could recommend that I add to the tail or structure prior to putting on the top. As an example, Tim you have some good photos on your site where you added angle to support the AHRS. What about ELT installation, etc. I would love to see some pictures of any installations that might be beneficial to copy. Also, where is the best place for the ELT to go?
Rick Leach
LarryRosen
Posted: Sat Sep 15, 2007 7:25 pm Post subject: Questions |
Seems to be 2 preferred locations for the elt. One under the far aft
under the vertical stab and the other is in the tail cone near the
baggage compartment bulkhead on the right side. Vans has a mounting
kit, but it is easy to make your self. The rear location puts the
weight far aft, and has a short wire run to the antenna.
Some items to complete prior to closing up the final skin on the tail
would be,
Any battery box modifications based on the battery you will be using.
Pitch servo installation
Wire pulls for battery, rear light and strobe, etc.
Strobe power supply mounting
AHARS (if you are mounting it in the rear and not a wing)
Static port tubing runs
Just a short list, but a start.
Larry Rosen
#356
Rick Leach wrote:
Rick Leach
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
