Deems Davis
Posted: Sat Sep 15, 2007 7:12 pm Post subject: Antenna placement and adequate ground plane or ground wir |
Zack thanks for the pic of Ricks install. Larry, I think it's going to
be easier to do the firewall shelf. I just spent 60 minutes in the
garage and bent up some .032" and riveted it into a decent 'shelf'. I've
already got 4 bolts that hold the voltage regulators to the inside of
the firewall that I'll use to attach this to. One thing I didn't account
for is the slight forward cant of the upper part of the firewall so
there is a bit of a tilt to the shelf that I'll have to take out with
some shims/standoffs. The cable/antenna runs for the cabin top install
are problematic for me.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Larry Rosen wrote:
Have you considered mounting them under the cabin top, inside the
Accuracy Avionics overhead console? I know there are two layers of
fiberglass and a core, but that shouldn't interfere with the signals.
(in my non expert opinion). Any thoughts?
Larry Rosen
Deems Davis wrote:
> With all this talk about antennas, I've got a question for the group.
> I need to mount a XM weather antenna and an additional GPS antenna. I
> already have the primary GPS mounted on the top of the tail cone aft
> of the cabin top intersection. I am not keen on placing them on the
> cabin top, primarily for aesthetics, so I'm planning on mounting them
> side by side on a shelf on the firewall. This will make installation
> and the cabling easier. The antennas don't require a ground plane as
> best as I can tell. Mounting them in this location will make for a
> shorter cable run and an easier installation. Anybody gone this
> route? Feedback? I think I recall that Checkoway mounted one or more
> antennas in this manner.
> Deems Davis # 406
