Rocker arm & Valve clearance
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
jsnafziger(at)yahoo.com
PostPosted: Mon Sep 10, 2007 12:54 pm    Post subject: Rocker arm & Valve clearance Reply with quote
I went over the rocker arm & valve clearance per the maintance manual
(task card 247). It states a clearance of 0.3 mm for both valves,
cold.
The clearances on mine (romanian m14p) were mostly 0.3 mm for the
intake valves, but 0.45 mm for the exhaust valves. I set them all at
0.3 mm per the manual, but due to the consistancy of the exhaust
settings, I thought I'd ask if anyone has found a similar thing?
The placard on the nose case states 0.010", but I thought 0.012"
(0.3mm) close enough.
John
http://smallbusiness.yahoo.com/webhosting
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
george(at)gesoco.com
PostPosted: Mon Sep 10, 2007 1:33 pm    Post subject: Rocker arm & Valve clearance Reply with quote
You are correct. .012 is closer. It is normal for them to ware. We recommend
adjustment at 30 hours from new and then every 100 hrs.
George
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
