ricksked(at)earthlink.net Guest
Posted: Thu Jan 05, 2006 11:42 am Post subject: flap-aileron trailing edge alignment |
Jay,
I thought the same thing and figured out the flap was not fully retracted. See if the top skin or something else is causing the flap not to fully seat against the rear spar. It was only a very small amount to completely seat and then it was fine.
Rick S.
40185
Fuselage
jhasbrouck(at)woh.rr.com Guest
Posted: Thu Jan 05, 2006 3:01 pm Post subject: flap-aileron trailing edge alignment |
Jay,
As an aside, my Piper Arrow was much the same way. Ailerons and flap
trailing edges did not align with one side being farther off the the other.
Asked an IA about it and got the usual "they're all that way" response.
After comparing the -10 construction to the factory built Arrow I have
confidence in the strenght of the -10 airframe.....john
LessDragProd(at)aol.com Guest
Posted: Thu Jan 05, 2006 8:45 pm Post subject: flap-aileron trailing edge alignment |
Per the Piper book, the Arrow uses the flaps to trim for roll. Been there, done that.
Jim Ayers
In a message dated 01/05/2006 3:03:00 PM Pacific Standard Time, jhasbrouck(at)woh.rr.com writes:
Jay,
