fluid level sensor needed
Goto page 1, 2  Next
rv8ch
PostPosted: Thu Feb 16, 2006 10:29 am    Post subject: fluid level sensor needed Reply with quote
Hi,
I'm looking for a fluid level sensor that I
will use in my Subaru engine cooling system.
I've found lots of on/off switches that will
tell me if there is coolant there or not, but
does anyone know of a reasonably priced sensor
that will give me analog output over a range
of values? Reasonably priced means to me
something less than about $250.
Thanks!
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
mark.steitle(at)austin.ut
PostPosted: Thu Feb 16, 2006 10:56 am    Post subject: fluid level sensor needed Reply with quote
Mickey,
How much space do you have to work with? Maybe you could use a
float-type fuel level sensor and shorten the arm so that it fits inside
the reservoir.
Mark S.
frank.hinde(at)hp.com
PostPosted: Thu Feb 16, 2006 11:19 am    Post subject: fluid level sensor needed Reply with quote
I don't know about a level sensor but in my ea81 I use a pressure
guage...If pressure goes away after take off it means I have a leak and
have to land anyway...Its worked pretty well for 400 hours.
Just an idea
Frank
rv8ch
PostPosted: Thu Feb 16, 2006 11:43 am    Post subject: fluid level sensor needed Reply with quote
the reservoir.
The tank is 4"x4"x3" so there is not a lot of space.
It will be a "zero pressure" system, or very low pressure.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
Mark Phillips in TN
PostPosted: Thu Feb 16, 2006 12:01 pm    Post subject: fluid level sensor needed Reply with quote
Have you taken a look at McMaster Carr?
click on: http://www.mcmaster.com/
and go to page 490- they have several pages of float switches for many uses.
Good folks to deal with- they sell a LOT of RV parts!
Mark Phillips
From The PossumWorks...
rondefly(at)rtriano.com
PostPosted: Thu Feb 16, 2006 12:22 pm    Post subject: fluid level sensor needed Reply with quote
You could use the fuel warning system, I am using it on my header tank when
it is low. It should work in the Rad also. Here is the ACS #, P/N 6905-400
$28.70
Ron Triano
http://bld01.ipowerweb.com/contentmanagement/websites/rtrianoc/page10.html
rv8ch
PostPosted: Thu Feb 16, 2006 1:58 pm    Post subject: fluid level sensor needed Reply with quote
Oh, yes, I know McMaster-Carr, as does my credit card.
I could only find on/off switches there, no analog switches.
I might have to punt on this and just go with a NO/NC
type switch. Perhaps I'm trying to get too fancy.
Thanks for all the suggestions!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
Earl_Schroeder(at)juno.co
PostPosted: Thu Feb 16, 2006 2:25 pm    Post subject: fluid level sensor needed Reply with quote
If memory serves me correctly, Jim Weir had a 'cheap' do it yourself
capacitance probe and op amp amplifier project several years ago. You
might search his site. Or the publication KitPlanes archives. Earl
raymondj(at)frontiernet.n
PostPosted: Thu Feb 16, 2006 3:42 pm    Post subject: fluid level sensor needed Reply with quote
Would it meet your needs to use 2 or 3 float switches with the floats set at
different levels. The fluid level could be defined within a range based
which switches are closed/open.
Good luck,
rayj
Original Message -----
To: <aeroelectric-list(at)matronics.com>
Sent: Thursday, February 16, 2006 12:27 PM
Subject: fluid level sensor needed
<mick-matronics(at)rv8.ch>
Hi,
Thanks!
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
mprather(at)spro.net
PostPosted: Thu Feb 16, 2006 3:53 pm    Post subject: fluid level sensor needed Reply with quote
Capacitors require a fairly decent dielectric media for the
between-the-plates insulator. Coolant isn't that (dielectric nor
insulating)...
<Earl_Schroeder(at)juno.com>
might search his site. Or the publication KitPlanes archives. Earl do
not archive
>> many uses. Good folks to deal with- they sell a LOT of RV parts!
PostPosted: Thu Feb 16, 2006 4:42 pm    Post subject: fluid level sensor needed Reply with quote
Not to be 'picky' here but insulated probes will measure a conductive
liquid quite well... used a bunch back at GE. Earl
insulating)...
> not archive
PostPosted: Thu Feb 16, 2006 5:35 pm    Post subject: fluid level sensor needed Reply with quote
Good point. How tough is it to make a probe that doesn't leak too bad..
I guess leakage adds series R to the RC circuit, so probably isn't too
critical, though I think it will damp the oscillator circuit.
http://www.rst-engr.com/rst/articles/KP89SEP.pdf
Discussion on dielctric strength.
http://www.usm.maine.edu/~newton/Chy251_253/Lectures/Solvents/Solvents.html
http://www.clippercontrols.com/info/dielectric_constants.html
This is still going to be a challenge - the glycol to water ratio isn't
always going to be the same, and the dielectric strength of water varies
with temperature..
How about a little camera with a light that lets you actually see a sight
tube?? Smile Put the sight tube for the coolant next to a sight tube for
the engine oil level. Have the camera display to the cockpit on a little
LCD..
Or how about adapt a fishfinder - mount it in the bottom of a tube within
the reservoir - pointed up, with a little float in the top of the tube.
The fishfinder will detect the distance between the sensor and the float.
Might have to work on improving the shallow water resolution.
Matt-
Matt Prather wrote:
> <mprather(at)spro.net>
> insulating)...
>> You might search his site. Or the publication KitPlanes archives.
>> Earl do not archive
paul.mcallister
Hi,
I built a fuel tank gauge based off a 0 ~ 1 " pressure transducer for my
Europa. Although you only have 0 ~ 4 " of head, I would say from my bench
experiments that this device is sensitive enough for your needs.
The sensor was a Honeywell 26PCAFA6D and I amplified its output with a
INA118P instrumentation op amp. It would cost you less than $25 in parts to
experiment with and I am confident that it would work for you.
Regards, Paul
nuckollsr(at)cox.net
PostPosted: Sat Feb 18, 2006 2:49 pm    Post subject: fluid level sensor needed Reply with quote
Hi,
Does this need to be a quantity gage or just
a low level warning?
rv8ch
PostPosted: Sat Feb 18, 2006 3:30 pm    Post subject: fluid level sensor needed Reply with quote
My goal is to know when it is low, but I don't
really trust an "idiot light" solution, which
is why I'd like some idea of the progression
from "ok" to "too low".
My fallback position is to install two on/off
type sensors at different levels, but that's
getting kind of kludgey.
Thanks for any hints!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
Larry McFarland
PostPosted: Sat Feb 18, 2006 4:47 pm    Post subject: fluid level sensor needed Reply with quote
Bob,
I use a pressure sensor in a threaded boss in a metal hose connection.
The warning is provided by
my Grand Rapids Technologies E I S. It's alarm is set at a minimum 4
psi. You loose water pressure
you know just as well that you don't have enough water to continue much
farther. A low fluid level would
not necessarily save your engine if it were placed incorrectly and might
be excess mechanics for what
you're trying to do. A pressure switch is smaller and simpler to do.
Larry McFarland - 601hds with Stratus Subaru
>Hi,
Larry McFarland - 601HDS - Stratus
rv8ch
PostPosted: Sun Feb 19, 2006 2:39 am    Post subject: fluid level sensor needed Reply with quote
Hi Larry,
Thanks for getting back to me.
Which pressure sensor are you using?
Paul's idea of using a Honeywell 26PCAFA6D amplified with a
INA118P instrumentation op amp is great, but I'm not
really qualified to do that much integration. I want
to run a zero pressure system, so using a sensor that
can detect such a small amount of pressure would be perfect,
assuming it's adequately damped.
I'm not planning to run any pressure in my system, but
this might change when my design meets reality. Still, I'm
having a little trouble understanding the relationship between
pressure and coolant loss. It seems like even if you have a
slow leak, and the coolant level goes down, the pressure
cap will maintain the correct pressure, even if it's only
air. I'm kind of new to this, so please excuse my ignorance.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
Larry McFarland
PostPosted: Sun Feb 19, 2006 7:47 am    Post subject: fluid level sensor needed Reply with quote
Mickey,
I used a Grand Rapids Technologies Part Number LPS-02 low pressure
sensor suitable for fuel and coolant pressures between 0-28 psi.
My coolant pressure is always above 5 psi so the low warning is set at 4
psi. If you're using a zero-pressure coolant in your engine
like the Evans waterless coolants, this might not be a good idea as they
only get pressure from pump flow.
GRT can be reached at Byron Center, MI ph 616-583-8000.
Larry
Hi Larry,
Mickey
PostPosted: Sun Feb 19, 2006 10:29 am    Post subject: fluid level sensor needed Reply with quote
Hmmmm . . . . but hard to beat for simplicity.
Reed switches operated with magnets on floats
are really inexpensive and reasonably reliable.
There are some optical level sensors with
possibilities. See:
http://www.gemssensors.com/electrooptical.htm
and
http://www.gemssensors.com/TOCResults.asp?nContentsID=29
I'm working on a one wire, no moving parts, thermally
sensed low liquid level detection system that will be
simpler to install and still more rugged but no schedule
on that activity yet. If you need something tomorrow,
consider the technology cited above.
For magnet and reed technologies, see:
http://www.gemssensors.com/TOCResults.asp?nContentsID=36
Some of these mount right through the sidewall of a
container. You could install more than one and use
simple indicator lamps to annunciate switch position.
rv8ch
PostPosted: Sun Feb 19, 2006 10:59 am    Post subject: fluid level sensor needed Reply with quote
That sounds like a winner. Please keep us posted.
Looks like I need to modify the expansion tank drawing
I sent to Canton Racing to add a couple of 1/4" NPTs
onto the side.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
Goto page 1, 2  Next
Page 1 of 2
