BMW
propellerdesign(at)tele2.
PostPosted: Sun Aug 26, 2007 4:06 am    Post subject: BMW Reply with quote
I will check with the friend from Poland, how many hours they have on this engine's, he just installed his, but have installed many on others plane inkl the school plane, he is also the one that got the bmw electronic box to work on airplane, there is 3 different manufactures of gear box, Poland, Czechoslovakia and Germany, he recommend the Cz gear box
The BMW 1100S is a modern engine that don't cost a lot, modern electronic injection, cheep on fuel, cheep to buy, 85-90 useful HP (depending on RPM) the torque is almost constant, I have pic from a guy in Poland that replaced his VW 1835 with a BMW he more then doubled the climb rate. speed up to VNE on his dragy TULAK (highwing side by side plane, MTOW 450 kg / 1000 lbs)
The pic is big is size so if any one want to see I can send to your private mail.
Jan
Reduction_for_BMW_from_Take_Off.pdf
 Filename:  Reduction_for_BMW_from_Take_Off.pdf
 Filesize:  235.41 KB
 Downloaded:  1204 Time(s)
bmw_r_1100-1150_data.txt
 Filename:  bmw_r_1100-1150_data.txt
 Filesize:  2.35 KB
 Downloaded:  1051 Time(s)
rflick(at)ovalinternet.ne
PostPosted: Fri Sep 07, 2007 9:45 am    Post subject: bmw Reply with quote
kuba;s email was gbam(at)gazeta,pl ([email]gbam(at)gazeta,pl[/email]) not sure if it is still the dame but give it a try. the guy is really knowledgeable about bmw. bill
PostPosted: Fri Sep 07, 2007 10:24 am    Post subject: bmw Reply with quote
Yes, one is to his work and one home, I never remember witch one is witch
Jan
