				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| Mike Bell
				|  Posted: Sun Feb 12, 2006 6:28 pm    Post subject: Yak 52 Fabric |   |
				| I am about to recover my Yak 52 control surfaces and have a couple of questions. I removed the rudder fabric and discovered the unusual way they do their rib-stitching. The ribs are drilled and the stiches go chord-wise instead of around the rib span-wise like most aircraft. Is this how others are doing the stitching?
 The yellow Russian primer is almost immune to MEK. That's supposed to mean it's OK to use Stits products without re-priming everything. Anybody had trouble with Stits being imcompatible with Russian primer?
 I have read of several fixes for cracked paint on the rudder. One thing that looks like it would help is to use 2 inch finishing tapes. The Russians use one inch, and that leaves the fabric directly touching the forward edge of the trailing edge metal with no reinforcement. My cracks seem to come from that area and radiate forward. Two-inch tapes on the ribs would stiffen the fabric too.
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
 Mike Bell
 Elk Grove, CA
 avbell2(at)comcastdotnet
		| Back to top |  |
		| Frank
				|  Posted: Sun Feb 12, 2006 8:12 pm    Post subject: Yak 52 Fabric |   |
				| Mike
The Russian primer is impervious to even paint stripper. I had to remove
 some from a few parts and I found a witches brew of MEK, 100LL, paint
 stripper, JET A and a few other things I can't remember did the job.....but
 not without allot of scrubbing
 Don't worry about the Russian primer...it's some of the best in the
 business. Your covering process won't touch it.
 As viewed from the rear, the upper left part of the rudder is prone to
 cracking on all YAKs due to pounding from the prop blast. Some people have
 put hard foam formers under this area to stiffen the fabric and help keep
 the paint from cracking due to the prop blast.
 Frank
		| Back to top |  |
		| Frank
				|  Posted: Mon Feb 13, 2006 4:42 am    Post subject: Yak 52 Fabric |   |
				| OH, Mike
 Forgot to mention that instead of rib stitching you can use the fabric
 rivets from Aircraft Spruce PN 09-18900.
 I've had them on my ailerons and elevator for 4 years now and no problems.
 Frank
		| Back to top |  |
		| cdustercc
				|  Posted: Mon Feb 13, 2006 4:49 am    Post subject: Re: Yak 52 Fabric |   |
				| I recently un-covered a bunch of control surfaces with the hard foam treatment inside.  They all had moisture damage.  It was apparent that they had been primed and painted before covering, but the foam held enough moisture to rust the tubing severly.  These were all in ag service so they were treated roughly and they had been sealed up for an estimated twenty years.  The foam was heavier than you would think so ballancing would be a concern.  I have read that on some severe applications, instead of using tape, people have double covered surfaces with success.  I think they used a heavy grade to cover, followed by the medium weight fabric all over instead of just where you overlap metal.  A gentleman at sun-n-fun told me that is how they used to cover the Howard DGA.
		| Back to top |  |
		| dsavarese(at)elmore.rr.co Guest
				|  Posted: Mon Feb 13, 2006 5:15 am    Post subject: Yak 52 Fabric |   |
				| The best fix I've seen so far, (I have no knowledge of using the Styrofoam
technique), is to put two round "button patches" about 1.5" in diameter,
 sewn between the surfaces of the rudder.  One about 3-4" in front of the
 trailing edge of the rudder midway between the ribs and the second one about
 8-10" forward of that.  This pulls the fabric taunt and helps eliminate the
 resonant vibrations we experience from the prop and so much left rudder.  If
 I'm not mistaken, the first Yak 52W's which did not have the metalized
 control surfaces, had these button patches from the Aerostar factory.
 Dennis
		| Back to top |  |
		| george(at)gesoco.com Guest
				|  Posted: Mon Feb 13, 2006 5:47 am    Post subject: Yak 52 Fabric |   |
				| Mike,
We use the Russian way of stitching. We also add a few "dollar" patches in
 the middle of the span on the rudder and a few stitches between the sides at
 the "dollar" patches. This helps keep the fabric from "drumming" and
 cracking paints.
 George Coy
 President
 Gesoco Industries Inc.
 629 Airport Rd.
 Swanton, VT 05488
 TEL 802-868-5633
 FAX 802-868-4465
 Web Site www.gesoco.com
 e-mail George(at)gesoco.com
 Franklin County Airport (KFSO)
		| Back to top |  |
		| Mike Bell
				|  Posted: Wed Feb 15, 2006 10:03 pm    Post subject: Re: Yak 52 Fabric |   |
				| Thanks to all for the on and off-line fabric advice. The "dollar" patches with a stitch over to the other side of the rudder seems to be a good fix for paint cracking. FWIW I recently attended the EAA weekend fabric class and asked the very experienced instructor if he had any suggestions and his was the same. The triangle patch sounds like a good idea too. Frank, the rivets instead of rib-stitching has a lot of appeal, and it's used on some certified aircraft. Do they stick up above the rib? I would hate to have something on a Yak-52 that's not totally flush with the airflow....
 Mike Bell
 Elk Grove, CA
		| Back to top |  |
				|  Posted: Thu Feb 16, 2006 4:46 am    Post subject: Yak 52 Fabric |   |
				| Yeah....it might increase the drag and slow it down.....or cause adverse yaw
or something........not!!!  -)
 Dennis
		| Back to top |  |
		| Frank
				|  Posted: Thu Feb 16, 2006 5:10 am    Post subject: Yak 52 Fabric |   |
				| Mike
The rivets are low profile. The amount they stick up is hardly noticeable as
 you tape over them just like you would with stitching. Any aerodynamic
 affects I think are minimal.
 Frank
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
