ron.mcgann(at)baesystems. Guest
Posted: Wed Feb 15, 2006 2:09 pm Post subject: Fuel Pump/filters |
G'day all,
Is Vans Fuel Injection Fuel Pump and Installation kit for the IO320 or IO360 (PNo 7/7A F.I. PUMP INSTAL) what we use in the -10? Does the pump have sufficient capacity for the IO-540? Vans site indicates "The AIRFLOW PERFORMANCE pump and filter is appropriate for any of the fuel injected Lycoming engine", but just looking for confirmation before I spend more bucks.
thanks in advance
Ron
#187 fuse
rv10es(at)earthlink.net Guest
Posted: Wed Feb 15, 2006 3:12 pm Post subject: Fuel Pump/filters |
I have the Airflow Performance pump and filter but my invoice only shows "ES AIRFLOW FILTER" and "ES AIRFLOW FUEL PUMP 20-25 PSI".
I don't know if this info will help you since I am not sure what IO320/360 use.
rob kermanj
rv10es(at)earthlink.net (rv10es(at)earthlink.net)
On Feb 15, 2006, at 5:07 PM, McGANN, Ron wrote:
| Quote: | G'day all,
thanks in advance
Ron
#187 fuse
Posted: Thu Feb 16, 2006 1:48 pm Post subject: Fuel Pump/filters |
Thanks for the response Rob. The items you cite are all that are required. Apparently the Fuel Pump and Installation kit contains stuff for the -7 that we don't need.
Ron
| Quote: | -----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of rob kermanj
Sent: Thursday, 16 February 2006 9:41 AM
Subject: Re: Fuel Pump/filters
rob kermanj
| Quote: | G'day all,
thanks in advance
Ron
#187 fuse
