Small Voltmeter
rparigor(at)SUFFOLK.LIB.N
PostPosted: Wed Feb 15, 2006 12:50 pm    Post subject: Small Voltmeter Reply with quote
I need a "SMALL" high quality voltmeter to put in the headrest of our
Europa. Bar or Digital OK but with reasonable accuracy between 11 and 17V.
Anybody know where to get one?
Thx.
Ron Parigoris
nuckollsr(at)cox.net
PostPosted: Wed Feb 15, 2006 6:41 pm    Post subject: Small Voltmeter Reply with quote
Don't have any digital meters in my bag of tricks. But I
could supply you with a miniature, expanded scale, analog
device.
It would look like it's little brother loadmeter at:
http://aeroelectric.com/Catalog/9007-100-1_Loadmeter.jpg
except the scale would run 10-15 volts. You can get
dimensions at:
http://aeroelectric.com/Catalog/AEC/9007/AEC9007-700.pdf
I'm working on a scaling module that mounts right on
the back of the instrument which is still going through
birthing pains. However, in the mean time, I could put
the scaling module into the same package as the product
shown on page 2 of
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1B.pdf
willslau(at)alumni.rice.e
UMA makes a 1-1/4" round voltmeter. I have no experience with it, but it
looks nice. www.umainstruments.com
William Slaughter
rd2(at)evenlink.com
PostPosted: Thu Feb 16, 2006 1:33 am    Post subject: Small Voltmeter Reply with quote
Hi Ron,
Some time ago I was searching for the same thing. These have digital LED
display; mounting bezel is available; the size is approximately of a hobbs
hour meter. Kinda liked LED better, because it needs no backlighting and is
much less temperature sensitive than LCD.
Main page:
http://store.cd4power.com/cgi-bin/cd4power.storefront/43f4387d045486c2271d0c
9f894206c0/Catalog/1013
Digital panel DC Volt meters (2 wire):
9f894206c0/Catalog/1042
I might still have a DMS-20PC-1-DCM V-meter that I can't use (8-50 VDC, red
LED, 2 wire) - see:
9f894206c0/Product/View/8076830
Data sheet: http://www.cd4power.com/data/meters/pc0-dcms.pdf
I think I might also have a DCA5-20PC Ammeter that I don't need (w/shunt, 3
wire, blue LED) - see:
9f894206c0/Catalog/1247
Data sheet: http://www.cd4power.com/data/meters/dca520pc.pdf
Rumen
_____________________Original message __________________________
(received from rparigor(at)SUFFOLK.LIB.NY.US; Date: 08:48 PM
2/15/2006 -0000)
Thx.
Ron Parigoris
