jfogarty(at)tds.net Guest
Posted: Tue Aug 28, 2007 11:55 am Post subject: pvc pipe |
Sam, I like your idea on the coupling for the PVC pipe to hold the pipe in place for the wing wiring. Did you use in t-couplings inside the wing? Also, thanks to the Possum Works for his good idea's on the 5/8 inch PVC pipe. Great.
Jim Fogarty
RV9a
sbuc(at)hiwaay.net Guest
Posted: Tue Aug 28, 2007 12:21 pm Post subject: pvc pipe |
Jim Fogarty at Lakes & Leisure Realty wrote:
| Quote: | Sam, I like your idea on the coupling for the PVC pipe to hold the
Jim Fogarty RV9a
Thanks Jim, the idea certainly did not originate with me.
I didn't use a tee mid-wing but I see no reason why you couldn't. When I
added the LRI I *carefully* cut a hole in the PVC mid-wing with a Dremel
so I could add the lines for the LRI probe. An existing tee would have
saved a few minutes.
Sam Buchanan
