frank.phyllis(at)mindspri Guest
Posted: Sat Aug 25, 2007 8:12 am Post subject: Series 7 Wt & Balance |
All
I just completed (I hope) the wt & balance for my Series 7 with a Rotax,
i.e. no fwd sweep in wing.
Wt came out to be 822 -- I'm happy with that.
What I'm questioning is the wheel measurements.
I dropped the wing leading edge (datum) and found it to be to the rear
of the main wheel axles by 2 3/8". (I actually had to drop the string
outside the main wheels because the string was touching the Grove Gear
leading edge.) The diagram/worksheet shows the wing leading edge to be
fwd of the main wheels.
Tail wheel was 164" behind leading edge.
What wheel measurements have you found on your S7?
Frank McDonald
N5929
Hopefully, ready for DAR
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Aug 25, 2007 10:51 am Post subject: Re: Series 7 Wt & Balance |
| Quote: | The diagram/worksheet shows the wing leading edge to be
fwd of the main wheels. |
If the leading edge is very far foreward of the main wheels it will be a nose Dragger. Thats probably the diagram they use in your manual.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Float Flyr
Posted: Sat Aug 25, 2007 12:03 pm Post subject: Series 7 Wt & Balance |
Did you have your tail wheel raised up to level the plane?
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Aug 26, 2007 4:10 am Post subject: Series 7 Wt & Balance |
Noel
Yes, leveled IAW instructions.
Frank
Float Flyr
Posted: Sun Aug 26, 2007 6:15 am Post subject: Series 7 Wt & Balance |
I thought it over after I made the last post and can't find anything wrong
with the mains being so close to the Datum.
Noel
[quote] --
Kitfox III-A
Posted: Sun Aug 26, 2007 10:10 am Post subject: Series 7 Wt & Balance |
Thanks, Noel
Frank
