paulrod36(at)msn.com Guest
Posted: Fri Aug 24, 2007 3:35 pm Post subject: Flap Indicator |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> While staring at Surplus's inexpensive flap motor, it struck me I hadn't thought any further about an indicator than putting painted lines on the left flap. Then my devious mind took over. Has anyone used an extra fuel quantity sender, and a re-painted VDO fuel gauge to serve as an indicator? Seems to me that replacing the float with an appropriate length of stiff wire riding in some sort of clip ought to do the job. Any thoughts on this?
Paul Rodriguez
601XL/Corvair
zodierocket(at)hsfx.ca Guest
psm(at)ATT.NET Guest
Posted: Fri Aug 24, 2007 5:11 pm Post subject: Flap Indicator |
Hi Paul
That sounds like a great idea. If you are using an EFIS you can
probably just plug the sensor into the EFIS to get a readout.
My approach is a little different. I have designed (but not yet
completed) a magnetic switch sensor to tell me when I have 10 degrees
of flaps. It will light a panel LED to indicate that. I can depend
on the limit switches to set the flaps to 0 and max.
You might want to contact your EFIS/EIS vendor and see if they can
suggest a sensor that will easily plug into their display box. That
might be a quicker and easier solution than the fuel sender approach.
Paul
XL fuselage
At 04:34 PM 8/24/2007, you wrote:
| Quote: | While staring at Surplus's inexpensive flap motor, it struck me I
Paul Rodriguez
601XL/Corvair
