n4546v(at)mindspring.com Guest
Posted: Mon Aug 20, 2007 1:38 pm Post subject: weight & balance with one scale? |
This is probably a Rookie question and is only for discussion as I have access to three scales, but if one wanted, could you correctly weigh an airplane with just one scale if you put scale height blocks under the other wheels as you moved the scale from wheel to wheel? First glance is that it would weigh correctly as long as the other wheels are at the constant height. Not very convenient though.
Randy, Las Vegas
dredmoody(at)cox.net Guest
Posted: Mon Aug 20, 2007 1:49 pm Post subject: weight & balance with one scale? |
As far as I know, Randy, you are correct.
Dred
vgstol(at)bigpond.net.au Guest
Posted: Mon Aug 20, 2007 2:03 pm Post subject: weight & balance with one scale? |
Yes, definitely can use just one scale, but don't just lift the aircraft to change from block to scale - the landing gear will flex and put a side load on the scale as the weight comes on it. Just need more blocks so that you can roll the aircraft on and off the scale.
Tailwinds always,
JG
Posted: Mon Aug 20, 2007 2:07 pm Post subject: weight & balance with one scale? |
Randy,
You'd be better to have 4 scales and rotate one out with each wheel to
check the accuracy of each as you go. I found four 300 lb scales at
$9.00 each
on sale and then made a lever-lift that picks up each wheel with little
effort as scales are slid under and out. You need a 1/4 inch thick 6 x
6 of aluminum to spread the
weight on each scale, but it works and is convenient. Takes about 15
minutes to do a W & B. The back link drops out for removal.
http://www.macsmachine.com/images/tjh/winghandling/full/scaleinsert.gif
http://www.macsmachine.com/images/tjh/winghandling/full/scaleplaced.gif
http://www.macsmachine.com/images/tjh/winghandling/full/scalew&b.gif
.good luck,
Randy L. Thwing wrote:
| Quote: | This is probably a Rookie question and is only for discussion as I
Randy, Las Vegas
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Mon Aug 20, 2007 3:26 pm Post subject: Re: weight & balance with one scale? |
One small detail worth mentioning. If you are also determining ballance, the plane ought to be in the horizontal flight attitude with the top longeron level when weighing. Then you can calculate the moments to the datum with no problem.
Dan Dempsey[/quote]
_________________ Scratch building XL with Corvair Engine |
pmaxpmax(at)HOTMAIL.COM Guest
Posted: Mon Aug 20, 2007 3:46 pm Post subject: weight & balance with one scale? |
That's how I did mine.
Phil Maxson
601XL/Corvair
Northwest New Jersey
| Quote: | From: n4546v(at)mindspring.com
Subject: weight & balance with one scale?
Date: Mon, 20 Aug 2007 14:37:27 -0700
Randy, Las Vegas
| Discover the new Windows Vista Learn more! [quote][b]
planecrazydld(at)yahoo.co Guest
Posted: Tue Aug 21, 2007 2:07 am Post subject: weight & balance with one scale? |
just curious: aren't the scales required to be certified for W&B use anymore?
Phil Maxson <pmaxpmax(at)HOTMAIL.COM> wrote:[quote] .hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } That's how I did mine.
Phil Maxson
601XL/Corvair
[quote] From: n4546v(at)mindspring.com
This is probably a Rookie question and is only for discussion as I have access to three scales, but if one wanted, could you correctly weigh an airplane with just one scale if you put [quote][b]
graeme(at)coletoolcentre. Guest
Posted: Tue Aug 21, 2007 4:37 am Post subject: weight & balance with one scale? |
Question
I have a Ch701 a friend of mine is building a ch601 HD which has been un touched for a number of years .
He hopes to soon be building again.
I mentioned the solid alloy gear legs .
Can he build his fuse to take the alloy legs ( the fuselage is not started )
he intends to build a tail dragger and has the wing mount wheel kit.
Thanks Graeme
Gig Giacona
Posted: Tue Aug 21, 2007 6:05 am Post subject: Re: weight & balance with one scale? |
Not in Experimental land.
| planecrazydld(at)yahoo.co wrote: | just curious: aren't the scales required to be certified for W&B use anymore?
601XL Under Construction
MaxNr(at)aol.com Guest
Posted: Tue Aug 21, 2007 10:48 am Post subject: weight & balance with one scale? |
I'm sure that a single scale (or two to average out) would be adequate. Sure, it takes a little longer. But how often are you going to do it? I would like to know if a 300 pound scale would be enough? What are the empty weights that builders are seeing on the MLG? The nose wheel? The price of scales go up for a 400 pound scale. Those analog spring scales may be inaccurate near their upper limits. I am going digital for the accuracy. I will try to borrow or rent because I'm cheap. Medical scales go up to 800 pounds. Alternatively: I weighed the tongue weight of my RV trailer using the mfg.'s published method. Bridge a solid fixed point and the scale with a 2 by 6 plank. Put the tongue on the plank at a 2/3 point. I doubled the reading and I found that the tongue weighed MORE OR LESS 700 pounds. I used a 300 pound bathroom scale. That's a whole lot of trouble for three wheels though.
Bob from Pace,FL 601XL/Lyc
*************************.com/memed/aolcom30tour [quote][b]
bryanmmartin
Posted: Tue Aug 21, 2007 11:57 am Post subject: weight & balance with one scale? |
Not for a homebuilt, any scale will do as long as you can get a fairly
accurate reading from it. My DAR never asked me how I weighed my plane,
just checked to make sure had a W&B sheet with my paperwork.
| Quote: | just curious: aren't the scales required to be certified for W&B use
anymore?
*/Phil Maxson <pmaxpmax(at)HOTMAIL.COM>/* wrote:
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
bryanmmartin
Posted: Tue Aug 21, 2007 12:09 pm Post subject: weight & balance with one scale? |
I would use two 300 lb scales in tandem. That way you can keep the
readings near midscale where it's more accurate and you don't have to
worry about overloading the scales. Just put a plank between the two
scales with the tire on the plank and add the two readings. Calibrate
them first with known weights.
MaxNr(at)aol.com wrote:
| Quote: | I'm sure that a single scale (or two to average out) would be adequate.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
Posted: Tue Aug 21, 2007 1:14 pm Post subject: weight & balance with one scale? |
Wow! I just can't believe how this activity has morphed in the last 30 years since I was last seriously engaged in it!
Did the DAR at the very least check the W&B sheet entries and math? Did he check the manufacturers/designers limits?
Wow!
Bryan Martin <bryanmmartin(at)comcast.net> wrote:
[quote]--> Zenith-List message posted by: Bryan Martin
anymore?
*/Phil Maxson /* wrote:
Bryan [quote][b]
Posted: Tue Aug 21, 2007 1:47 pm Post subject: weight & balance with one scale? |
Bryan,
My weight empty with oil and coolant is 265, 264 mains and 231 for the nose.
I found my 300 lb scales are accurate +/-1 lb so long as you place a 1/4
inch aluminum plate under each tire for weight distribution.
Bryan Martin wrote:
> nose wheel? The
t_fogelson(at)yahoo.com Guest
Posted: Tue Aug 21, 2007 2:59 pm Post subject: weight & balance with one scale? |
I seem to remember when studying for the A&P test that
the plate should be greased so as the weight was
placed on the scale that it would slide and relieve
any sideways stress. That was a long time ago and in
a galazy far far away.
Terry
--- LarryMcFarland <larry(at)macsmachine.com> wrote:
Bryan,
distribution.
you can keep the
readings. Calibrate
out) would be
often are you going
>> nose wheel? The
browse
Subscriptions page,
FAQ,
Web Forums!
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
Posted: Tue Aug 21, 2007 4:49 pm Post subject: weight & balance with one scale? |
Am I the only one to catch my math error on my "alternative method?" Double it if the weight is center plank. Seriously, its a clunky way to do the deed, but its still my fall back method. I will be looking for at least a 330 lb digital scale. My ball park figures for a plane not yet completed are based on some numbers from completed Lyc 601XL's. And that is north of 800 lbs empty weight. I hope I'm pleasantly surprised. I'm just guessing that the weight on the mains would be at least 650. Another thing. Not to offend, but I'm converting MM's to inches and do the chart C in Yankee inch/pound moments. I've been doing W/B in that format for half a century and I'm too old and ornery to change. I can build in metric but flying is another thing. When I was working for the man, I had been handed many manifests in kilos and even Stones. No problem. Furthermore, I've given some thought to moving the datum to the prop hub so that I don't have to compute with negative numbers. It does say "experimental" on the airplane after all. This will conform with most every thing I've flown in the past 40 years. Except for my 46 Luscombe and anything else certified before there was an FAA.
Bob from Pace,FL XL/Lyc
****************cover.aol.com/memed/aolcom30tour [quote][b]
grs-pms(at)comcast.net Guest
Posted: Tue Aug 21, 2007 5:51 pm Post subject: weight & balance with one scale? |
Bob:
There is nothing experimental about moving the datum to any convenient point. At Boeing, as I remember, the zero datum is commonly placed ahead of the nose. so there can be no negative moments. (Well, I admit to a few negative moments while I was at Boeing, but that's another matter.) It was also common to use a "constant moment" diagram to simplify weight and balance calculations. Have you used that sort of W/B presentation?
George
rsteele(at)rjsit.com Guest
Posted: Tue Aug 21, 2007 6:32 pm Post subject: weight & balance with one scale? |
To each his own. I just can't imagine going back to feet and inches. I do woodworking and worked as a surveyor in my younger days so I've even worked with decimals of feet - yuck. I've been looking for metric tools so when I go back to woodworking, after the plane, I don't have to revert to the 17th century. Metric tools are just not available locally, I guess I might have to order them from Canada.
If you are talking about using a digital "bathroom scale" be aware that it may be less accurate than an analog one. They still use a spring balance, but they have to include a digitizer too. I'd stick with a high quality dial scale. The Taylor Professional, which I have upstairs, goes up to 330 pounds. I think I picked it up at Sam's Club a few years ago for about $35. Someone suggested calibrating the scale with known weights, which is the best thing to do. Maybe a few sacks of cement? 90lbs each if I remember right. If you calibrate, the actually reading isn't as important as consistency. If the readings are consistent, you can factor out the errors.
BTW, calculating wights and balance for the scale is exactly the same as it is for the plane. You can reasonable use a lighter scale and place a board between the scale and a support. The same math you use to figure W/B is used "in reverse" to get the true weight of the wheel. The support needs to be the same height as the scale, and should be a "knife edge" or round so that it can roll. The goal to make sure the support allows the board to pivot freely. Be VERY careful with such a setup. Don't want to drop a plane.
Keep us posted on what you end up doing, and how it works.
Ron
On Aug 21, 2007, at 8:49 PM, MaxNr(at)aol.com (MaxNr(at)aol.com) wrote:
[quote]Am I the only one to catch my math error on my "alternative method?" Double it if the weight is center plank. Seriously, its a clunky way to do the deed, but its still my fall back method. I will be looking for at least a 330 lb digital scale. My ball park figures for a plane not yet completed are based on some numbers from completed Lyc 601XL's. And that is north of 800 lbs empty weight. I hope I'm pleasantly surprised. I'm just guessing that the weight on the mains would be at least 650. Another thing. Not to offend, but I'm converting MM's to inches and do the chart C in Yankee inch/pound moments. I've been doing W/B in that format for half a century and I'm too old and ornery to change. I can build in metric but flying is another thing. When I was working for the man, I had been handed many manifests in kilos and even Stones. No problem. Furthermore, I've given some thought to moving the datum to the prop hub so that I don't have to compute with negative numbers. It does say "experimental" on the airplane after all. This will conform with most every thing I've flown in the past 40 years. Except for my 46 Luscombe and anything else certified before there was an FAA.
****************cover.aol.com/memed/aolcom30tour | Quote: |
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
| [b]
bryanmmartin
Posted: Tue Aug 21, 2007 7:21 pm Post subject: weight & balance with one scale? |
His main concern was to make sure the paperwork was correct and
everything was properly labeled and placarded. He did look over the
plane and suggest some minor issues that needed correcting. I don't know
how carefully he checked the math, the W&B sheet I used was published by
Zenith with the limits printed on it. All I did was fill in the blanks
and calculate the moments and CG.
David Downey wrote:
| Quote: | Wow! I just can't believe how this activity has morphed in the last 30
Wow!
> anymore?
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
bryanmmartin
Posted: Tue Aug 21, 2007 7:29 pm Post subject: weight & balance with one scale? |
My nosewheel load was a little over 300 lbs and it was just easier to
put three 50 lb sandbags on the scales to verify accuracy than to mess
with five or six.
LarryMcFarland wrote:
Bryan,
nose.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
