Is a Relay Needed?
Don.Alexander(at)astenjoh
PostPosted: Wed Feb 15, 2006 5:28 am    Post subject: Is a Relay Needed? Reply with quote
I am getting ready to wire up my Ray Allen stick control buttons. One
of the functions that I am using will be for the flaps. (RV-Cool I have
tested the flap motor without an "air" load on the flaps and get a bit
over two amps when running. Ray Allen indicates that their switches are
rated for five amps. Do I need to include a relay in my circuit with
this sort of margin?
Don Alexander
nuckollsr(at)cox.net
PostPosted: Wed Feb 15, 2006 6:42 pm    Post subject: Is a Relay Needed? Reply with quote
At 08:08 AM 2/15/2006 -0500, you wrote:
<Don.Alexander(at)astenjohnson.com>
Don Alexander
Yes. Inrush currents on your motors are perhaps 10x bigger
than running currents. Suggest you pick from among the varieties
at:
http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps.pdf
Erich_Weaver(at)URSCorp.c
PostPosted: Thu Feb 16, 2006 4:15 pm    Post subject: is a relay needed? Reply with quote
Don Alexander
Don:
Im doing a similar set up on my RV-7A. Make your life easy - Vans has a
flap controller circuit board all ready for you. Check it out at:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1140134994-90-39&action=search
Erich Weaver
