Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
speckter(at)comcast.net Guest
Posted: Wed Aug 22, 2007 5:49 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
I was wondering too what had happened. Where is everyone, building?
Gary
40274
LloydDR(at)wernerco.com Guest
Posted: Wed Aug 22, 2007 6:02 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
Maybe we should talk about alternative engines? GRIN. Going down to
Florida tomorrow to mount my new carbon fiber cowl. Should loose a
couple more pounds, just where I don't need to!
Dan
N289DT RV10E
rv10(at)sinkrate.com Guest
Posted: Wed Aug 22, 2007 6:05 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
Were all hanging our subie engines!
AV8ORJWC
Posted: Wed Aug 22, 2007 6:08 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
Matt, thanks for providing such a great collaborative website for the
world's greatest group of kit builders.
Primer is a VERY personal thing and opinions can run rabid with little
provocation. Several of the products about to be espoused are excellent.
Primer is a "primary" step in the long-term application of permanent
topcoat. As such, the correct primer should be used by following a
correct technique after you select the topcoat of your own choice.
Primer is absorbent and as such can increase the likelihood of
hydrocarbon, dirt, moisture and other organic compound buildups.
Undesired corrosion can be the result. Primer-Filler is a whole nother
beast.
Study the products and their applications before taking the plunge.
Poly-urethane topcoats which are highly resistant to fuel and
hydrocarbon byproducts require a specialized primer for correct bonding.
At work, the topcoat instruction is the proper preparation and
application of fresh primer within two hours of topcoat. And yes, the
primer too, is a 2 part epoxy. Proper cleaning, proper prep, then
correct product, properly applied leads to years of discussion on the
subject.
Good luck teasing Ken Krueger to advise in writing on why there is no
conventional third wheel. I believe a strong basis was the strength and
weight necessary to support the IO-540 (up front) and the more docile
handling and insurance liability cost reduction by keeping the aircraft
out of the hands of "Real Men".
Know the mission, know the pilot capability, design for widespread
acceptance. So - 90 flying in three years and 800 kits would support
they (the VAN RV-10 team) steered clear of the ground loop insurance
costs.
John C - KUAO
Do not Archive out of respect for the search engine.
DAVELEIKAM(at)wi.rr.com Guest
Posted: Wed Aug 22, 2007 6:09 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
I'm not priming anything. Hah!
Dave Leikam
40496
flywrights(at)yahoo.com Guest
Posted: Wed Aug 22, 2007 7:41 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
I'm still in buildus interruptus. Should close on the house on Friday or early next week, just in time to go to Iraq for some flying,then come home in three months, take a few weeks to set up shop in the new hangar, then start building again by about December! :[
I'd like to start up some more conversation on the newest things since OSH about the simple EFISs, like when is Tru-Trak shipping, the AFS units - are they being installed? The website hasn't updated any installations for about a year now. Any other units out there that provide simple EFIS capability without Dynon's heavy reliance on pitot-static for AHRS-type info? Oh yeah, don't forget to keep the price down on your recommendations, either, because I have to build the rest of the panel around it - GPS/COM/NAV, AP head, Comm 2, etc.
Rob
#392
wayne.e(at)grandecom.net Guest
Posted: Thu Aug 23, 2007 4:36 am Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
Hell I thought everyone made there 10's a trail dragger not just me :>}
I'll add a little bit to the mix to help fill up Matt's band width. I'm now official, I have flown off my 40 hours. I thought once you got into the cockpit that you were done but boy you find, or at least I have, a whole lot of other issues have to be dealt with. Maybe others didn't run into some of the things I did, but I'll list a few of them.
I purchased my engine from Aero in Canada. They are really great people to work with and after talking to quite a few builders I find out they have a much better warranty policy than some. As an example, Mattituck engines warranty starts I believe when you receive the engine. I know of two RV builders who aren't finished yet and there warranty has or is about to expire because of time. On my Aero engine the warranty didn't start until my first flight. Also I bought a new engine from them, one that they built up from certified parts, and I have 3 years warranty. The warranty when you buy a new Lycoming certified engine, per what I've been told, is only 2 years.
Anyway to my point on debugging problems. On my first flight my left magneto decided to go to magneto heaven. So I was down for awhile awaiting a new mag from Aero. They shipped it right out but I had to get it installed and timed. I forgot to say that I have Lasar electronic ignition. We timed up the system, actually I use we loosely since I'm not very experienced with this type of thing and had to recruit help. Ron Grover and Danny King helped me. Anyway I've been chasing now a 200 mag drop on run-up and trying to figure out what the problem is. It's a uniform mag drop between the mags. If I lean out the mixture on run-up the mag drop goes to the normal tolerance.
First someone suggested leaning out the idle mixture, which really has no effect on the mixture at 1700 rpm. No cigar. Then someone said I should switch to fine wire plugs and that would solve the problem but after nearly $800 still no cigar. The thought then was that the fuel servo was not calibrated correctly so Aero sent me a new one, which I then installed. No cigar again. I tested in the air while running at 23 sq turning just to one magneto and then the other magneto. I had little or no mag drop. Anyway after all of that I'm still chasing this issue. I keep coming back to when we timed it, but we did it twice, per their instructions. So that's one of my issues.
Not to bore you too much but I'll give you another just to help Matt out :>} I have dual Chelton's installed with the Free Flight 1201 certified WAAS GPS receiver to drive them. From the beginning I wasn't able to get into what Chelton calls Ground Maintenance Mode (GMM). You have to insert a Smart Card and then power up the unit and it boots up in a mode that allows you to go in and configure the units to match your configurations and parameters, i.e. equipment, speeds etc. We chased that for quite awhile thinking somehow I had bad Smartcards or I was a dummy putting them in wrong, that maybe was a good guess :>} but anyway it was concluded that somehow the database for the units was corrupted and wouldn't allow me to go into GMM. I worked with a couple fellows at Chelton, Mike and Robert, on this, they are really a couple of good guys and very patient and knowledgeable, and they e-mailed me a new set of software and by using DOS commands with a keyboard attached to the Chelton, we were able to load this software into the units and the units would now come up in GMM. OK so far but new problem, now I had no GPS into the units from the Free Flight GPS.
I flew my next four flights using a sectional and following VOR radials, I have some steam gauges also. I guess I needed the practice anyway. Well it was finally determined, after I talked to Stein on a Sunday morning, that they have two version of their software a regular version -2 and one for people who have a Free Flight GPS, like me -8. You guessed it, they had mistakenly sent me the wrong one. I loaded that version and am now back in the GPS business. I now have to upgrade to the latest version, which is 6.0A16-8 where the 8 means for the Free Flight.
Anyway you get the point that you are, or at least I have been, presented with a whole new set of issues you have to deal with, however I have to say that being flying they aren't quite as frustrating as when I was in total build mode wanting to be flying.
I'm in TX and I have a hangar on an airpark just north of Fort Worth, Propwash Airpark. If any of you other 10 builders are coming to the area and would like to have a ride let me know. I'm going into paint on Sept 6th so I'm probably out of business for Sept.
OK Matt is that enough now :>}
Wayne Edgerton #40336
N602WT flying
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sat Aug 25, 2007 1:31 pm Post subject: Testing 1 2 3 - Is This Thing On? Where'd Everyone Go? |
Thanks for the write up.
Kevin
40494
no not archive
----- Original Message Follows -----
Subject: Re: Testing 1 2 3 - Is This Thing On?
Date: Thu, 23 Aug 2007 07:35:14 -0500
| Quote: | Hell I thought everyone made there 10's a trail dragger not
just me :>}
<snipped>
| Quote: | Wayne Edgerton #40336
N602WT flying
_________________ Kevin
40494
do not archive |
