cjensen(at)dts9000.com Guest
				 Posted: Tue Aug 28, 2007 11:06 am    Post subject: fun last Saturday |
				A badge on the chest and a  gun on the hip makes ordinary people go insane....at least without a lot of  education and training.  Bureaucrats are equipped with both badge and gun,  at least symbolically, even if they are not physically present, thus sane  behavior is not to be expected in all cases.
  In this immediate instance,  I can say with certainty that nuclear plants do not have a "bird watcher"  job.  Certainly, if there is a plane that does loiter at low elevation in  the vicinity of the plant, they'll take notice as they apparently did in this  case.  (Speculation begins here) They probably picked up their HS hotline  and reported that a plane was loitering in the area of the plant at a low  altitude.  When asked to identify the plane, they responded that it had an  engine, tail and two wings.  Since you were next to land and you EXACTLY  met the description, you became a participant to a meeting with Officialdom  without a prior appointment.  Know this; you will make some gumshoe's daily  report as proof that they are busy averting "terrorism by small aircraft"  and that the world is safer because of their unstinting vigilance (or is that  vigilantism).
  Of course, if you were  smuggling a monkey under your hat, they would have let you pass without  questioning.  Sweeeet, isn't it?
 Chuck Jensen
   -----Original  Message-----
 From: owner-rocket-list-server(at)matronics.com  [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Frazier,  Vincent A
 Sent: Tuesday, August 28, 2007 2:14 PM
 To: william  hilling
 Subject: fun last  Saturday
 Check this out.  These are 100% real events from my  life.  If this stuff ticks you off, please do something about it.  I  suggest writing your elected officials, protesting in front of their offices,  etc.
 This is every bit as dangerous to aviation as user  fees.  And if you don't agree, just look how long there has been a TFR  around Washington D.C. now.  Do you think we'll ever be allowed to fly  there again?
 Now it appears that even legal flights are becoming  illegal.
 Vince
  August 28, 2007
 The Honorable Evan Bayh
 United States  Senate
 131 Russell Senate Office Building
 Washington, D.C.  20510-1404
 Dear Senator  Bayh:
 I am contacting you regarding a  totally unacceptable event which occurred to me and a friend on Saturday, August  25, 2007.
 I own a plane which I use for  traveling throughout the Midwest.   On Saturday I flew from Evansville, IN to Benton Harbor, MI and then on  to Houghton Lake , MI.  I was  accompanied by a friend, who was flying his own plane.  Both planes also carried one  passenger.
 After assisting our passengers, who  were in Houghton Lake to purchase an aircraft, my friend and I departed and flew  back to Benton Harbor, MI.  Within  minutes of landing at Benton Harbor, we were detained by 2 well armed police  officers who were acting under the direction of Homeland  Security.
 Homeland Security had received a  report of aircraft flying near the Palisades nuclear power plant, apparently  from an observer at the plant whose job is to watch for aircraft.   The police officers asked for our  identification and recorded the registration numbers on our aircraft.  The police officers had no real  indication if they were looking for our aircraft or some other aircraft(s) who  may have been the real target. They relayed this information to Homeland  Security, who gave the officers physical descriptions of me and my friend to  confirm our identities.  The  officers departed after confirming our identities.
 We were given no explanations as to  why we were detained other than that we had flown past the power plant, a flight  that is perfectly legal to do as I will explain below.  Detainment of law abiding citizens  is  completely unacceptable to me  and should be to you also.
 First, I realize that many areas  were off limits to aircraft after 9/11 and that nuclear power plants were  previously  under TFRs (temporary  flight restrictions, issued by the FAA, often at the advise of Homeland  Security).  These TFRs were  rescinded long ago.  In their place  is FAA advisory 4/0811 (reprinted below my letter for your convenience) that  admonished pilots avoid these areas anyway.
 An FAA advisory has no enforcement  teeth.  However, FARs (federal  aviation regulations) do have teeth.   The FARs (also reprinted at the end of this letter) state that  "aircraft may not be operated closer than  500 feet to any person, vessel, vehicle, or structure."  This is the primary rule regarding flight  in uncontrolled airspace.  The  airspace around the Palisades nuclear power plant is uncontrolled.  In fact, the plant isn't even shown on  the FAA approved sectional map used for navigation.  And we were never within 500 feet of any  part of the plant.
 Because of the now rescinded TFRs  and the current 4/0811 advisory  I  knew EXACTLY how close I flew to the Palisades nuclear plant.  As we descended to land at Benton  Harbor, traveling in a straight line with no turns, our planes passed the plant  at over 2500' AGL (above ground level) and over 1 mile away.  We were traveling at 175 mph, it could  hardly be claimed that we were loitering.   This situation beats the standard  and intent of the FARs and the advisory by anyone's  interpretation!
 While a 500,000 pound airliner going  500 mph might be able to burn down a skyscraper, general aviation aircraft like  mine that rarely weigh more than 2000 pounds and rarely go faster  than 200 mph are hardly a threat to  anything or anyone except the pilot and passengers!  Certainly our aircraft were NO threat to  a nuclear power plant!
 Considering that the United States  of America is now home to 12,000,000 illegal immigrants who include a large  percentage of criminals, terrorists, uneducated  individuals, and other undesirables I  demand to know why Homeland Security is wasting time by detaining law abiding  citizens!?
 In closing I'd really like to see  the following actions from your office:
 1) Tell me what you are  doing, or will do in the very near future to keep law abiding pilots like myself  from having our name added to some data base kept in the bowels of some Homeland  Security office.
 2) Restructure Homeland  Security immediately to deal with the HUGE problem of illegal immigration.  Otherwise Homeland Security needs to be  abolished since they seem to have no other real function aside from harassing  law abiding citizens.
 3) Contact the NRC and  Homeland Security and find out why they require power plants to have employees  who are apparently paid to "bird watch" all day long.  While you're asking them why they have  these positions, find out what type of training these "birdwatchers" have.  Can they really tell what a threat looks  like?  Obviously  not!
 The United States of  America was built on freedom, not on detaining law abiding citizens.  Furthermore, it was built by legal  immigrants, not by undesirables infiltrating at will.   Do something about  it!
 Sincerely,
 Vince Frazier
 3965 Caborn  Road
 Mount Vernon, IN  47620
 812-464-1839  daytime
 FDC 4/0811 FDC ...SPECIAL NOTICE... THIS IS A RESTATEMENT  OF A PREVIOUSLY ISSUED ADVISORY NOTICE. IN THE INTEREST OF NATIONAL SECURITY AND  TO THE EXTENT PRACTICABLE, PILOTS ARE STRONGLY ADVISED TO AVOID THE AIRSPACE  ABOVE, OR IN PROXIMITY TO SUCH SITES AS POWER PLANTS (NUCLEAR, HYDRO-ELECTRIC,  OR COAL), DAMS, REFINERIES, INDUSTRIAL COMPLEXES, MILITARY FACILITIES AND OTHER  SIMILAR FACILITIES. PILOTS SHOULD NOT CIRCLE AS TO LOITER IN THE VICINITY OVER  THESE TYPES OF FACILITIES.
 FAR Sec. 91.119
 Minimum safe altitudes:  General.
 Except when necessary for takeoff or landing, no person may  operate an aircraft below the following altitudes:
 (a) Anywhere. An  altitude allowing, if a power unit fails, an emergency landing without undue  hazard to persons or property on the surface.
 (b) Over congested  areas. Over any congested area of a city, town, or settlement, or over any  open air assembly of persons, an altitude of 1,000 feet above the highest  obstacle within a horizontal radius of 2,000 feet of the aircraft.
 (c)  Over other than congested areas. An altitude of 500 feet above the  surface, except over open water or sparsely populated areas. In those cases, the  aircraft may not be operated closer than 500 feet to any person, vessel,  vehicle, or structure.
 href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
