OV protection-JD Alternator/VR
smineart(at)mahaska.org
PostPosted: Wed Feb 15, 2006 4:42 am    Post subject: OV protection-JD Alternator/VR Reply with quote
Has anyone used Bob's OV protection hardware with the John Deere 18amp alt and voltage regulator, AM101406, like used on the Wynne Corvair conversion? Would it be similar to the setup on Z-16, the Rotax system with PM alternator?
Steve Mineart, CH601
nuckollsr(at)cox.net
PostPosted: Wed Feb 15, 2006 5:15 am    Post subject: OV protection-JD Alternator/VR Reply with quote
with PM alternator?
All PM alternators (and internally regulated wound field
alternators) share a common characteristic in that they
cannot be absolutely controlled from the outside. Hence
the need for opening the main power lead from the device
(high current) as opposed to opening the field circuit.
Incorporation of OV protection for this class of alternator
is illustrated in Z-16 and is applicable to any instance
where the builder desires the protection.
