Lanny Fetterman
Joined: 10 Jan 2006 Posts: 37 Location: Catawissa Pa.
Posted: Tue Aug 21, 2007 4:38 pm Post subject: No Title |
Dana, The noise you hear in the wing is probably the rivet heads from the
pop rivets, not a concern. When I fold and unfold my FSII, I use a step
ladder of the correct height to rest the wing tip on. I hold the wing in
place with a bungi cord attached to the step ladder and wrapped around the
counter balance on the aileron and back to the step ladder. Then I put the
clevis pin in, that holds the wing in position. Once the pin is in, and the
wing can`t move aft, I loosen the bungi and attach the strut to the wing,
then I lift the wing off the ladder with the strut, and attach the strut to
the fuselage. Lanny Fetterman N598LF
_________________ Lanny Fetterman Firestar II N598LF |
