Jugle
Joined: 04 Aug 2007 Posts: 47 Location: Victoria, Australia
Posted: Sun Aug 19, 2007 10:32 pm Post subject: 601 XL layout sheets question |
Please tell if I'm missing something, but the PDF layout sheets available at http://ch601.org/builder%20resources.htm have me a little confused.
On each sheet there is a small table titled "Colour Code". It appears to list the material thicknesses, then in the next column is a list of colours. I don't understand how this relates to the layout sheets, as each sheet has a thickness stated at the top of the page. Can someone please clarify?
Thanks, Glenn
zodierocket(at)hsfx.ca Guest
Posted: Mon Aug 20, 2007 3:49 am Post subject: 601 XL layout sheets question |
Glenn, the layouts are a helpful item in saving waste, however you will
need to print them off and reference each part to the plans in order to
make sure that they are up to date and correct. The 601XL has changed a
lot over the years to harmonize the kit with the SLSA model. Both planes
are now constructed the same.
Print off the sheets, go through the plans and ensure that each part is
listed in it's proper area and sheet. Other builders have spent the time
to provide the layout for you, however as in everything it is your
responsibility as a plans builder to go through your plans and ensure
your list and layout are correct.
As for the colour coding on the sheet layout, I never tried to
understand it. It wasn't important when I double checked with my plans.
Though I was already passed the state of needing the layout.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
lwinger
Posted: Mon Aug 20, 2007 5:28 am Post subject: Re: 601 XL layout sheets question |
You're right. The legend is confusing. All the information on thickness that you need is at the top of each sheet. However, they also chose to color code the thickness by using a different color for the outline of each aluminum sheet and piece.
Additionally, they wanted to indicate where the parts would be used. The first four colors correspond to parts of the plan set. T = Tail, B = Body, W = Wings and C = Canopy. That information is provided by the color used to label each part.
Soooo, if you are on page 5 which is 0.040 thick, the color used to outline the sheet and each part is green. Inside each part, the color varies based on location of the part. So, the long parts at the bottom (wing spar webs) are outlined in green to show thickness and the labels are written in magenta to indicate they are for the wings.
Hope that helps. I had the same confusion.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Jugle
Posted: Mon Aug 20, 2007 2:27 pm Post subject: Re: 601 XL layout sheets question |
Thanks Mark and Larry,
My main concern is to compile quantites so I can start ordering some sheets. I thought those guides would assist in getting total number of each thickness required... which they will, but I have been going through the plans working it out anyway.
Thanks again,
Glenn.
_________________ Glenn Andressen
601XL- Rudder, Stabiliser parts completed, Wing ribs, nose ribs done, 70% Fuselage parts made. |
