ckhand(at)earthlink.net Guest
Posted: Tue Feb 14, 2006 10:46 pm Post subject: instrument wiring |
I'm working on installing wiring and panel stuff in my RV-6A. The Van's fuel gage and ammeter installation instructions say to use 18 AWG wire for the power, ground, and sensor wires on the fuel gages and for the power and ground wire on the ammeter. I didn't read that until after wiring up with 22 AWG as I didn't think the current draw was significant enough to warrant anything bigger - based this on an estimate of ~0.4 amps max per instrument from reference material I looked at (yes, I looked through several books but didn't read the instructions that came with the instruments....).
Am I that far out on my load estimates? Anybody think 18 AWG is really necessary for powering these instruments? I'm wiring these independently, not daisy chaining them as shown in the Van's drawings.
Thanks for any feedback,
Chris Hand
RV-6A, finishing stages
lhelming(at)sigecom.net Guest
Posted: Wed Feb 15, 2006 4:53 am Post subject: instrument wiring |
Dan.Beadle(at)hq.inclines Guest
Posted: Wed Feb 15, 2006 7:00 am Post subject: instrument wiring |
The issue of using smaller wire comes down to the circuit breaker.
If you use 22 wire, you need a smaller CB. The general idea is the CB
should pop before the wire heats enough to cause a fire.
So, if you have a star arrangement where several gages share one CB, the
normal current in any one wire is low - say the .4A you call out. But
if you put 6 of these together, you need a 3.2 A break. So you use a
5A, next bigger. But, then, you need wire that will carry 5A without
overheating long enough to pop the breaker.
As long as the wire doesn't overheat if it has to pop the breaker, you
would be OK. So make sure that each wire from a breaker, including
ground return lines, are sized to match the breaker and the load.
Dan
nuckollsr(at)cox.net Guest
Posted: Wed Feb 15, 2006 6:44 pm Post subject: instrument wiring |
At 10:35 PM 2/14/2006 -0800, you wrote:
Quote: |
<ckhand(at)earthlink.net>
instruments....).
No, 22AWG is plenty for anything an instrument would need
for either power, signal or lighting conductors.
