gareywittich2000(at)yahoo Guest
Posted: Fri Aug 17, 2007 8:35 pm Post subject: Running VOR coax cable thru VS |
Ready to drill hole in VS ribs (Top and Middle ribs)
to run VOR coax cable thru them for cat-wisker VOR
type antenna mounted on top of VS.
Where have you Builders drilled the hole for the coax
on the ribs - middle of ribs, on the rib closer to the
Front Spar or on the rib closer to the Rear Spar ???
Was a doubler plate used on the ribs, with the coax
holes, to make up for the the ribs loss of structural
strength ??
On the bottom rib, it has 3 lightening holes that
would allow the coax to run thru one of them into the
fuselage - correct ???
Thanks, Garey
| - The Matronics RV8-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
N715RR
Posted: Sat Aug 18, 2007 2:09 pm Post subject: Running VOR coax cable thru VS |
garey, drill forward of the forward spar....It will interfer with the rudder otherwise..You only have that first 6 inches or so with a fiberglass cap...
strength ??
Thanks, Garey
