Lee Francke
Joined: 02 May 2007 Posts: 3 Location: Prairie du Sac, WI
Posted: Fri Jun 27, 2008 3:44 pm Post subject: Elevator cables modification |
Is there any reason why instead of putting the turnbuckle at the control stick in center console.
That you could not put the turnbuckle in the center (over the bottom access door) of the cable running to the elevator and use thimbles and shackles on both end attachments.
This would make it easier to adjust.
Jaybannist(at)cs.com Guest
Posted: Fri Jun 27, 2008 4:09 pm Post subject: Elevator cables modification |
Melvin,
I put the turnbuckle on the upper cable in the arm rest area, and attached the other turnbuckle to the upper control horn of the elevator. I have screw attachment of the fiberglass saddle that covers that turnbuckle, so access is real easy.
Jay in Dallas
"Melvin Francke" <mlfrancke(at)charter.net> wrote:
| Quote: | Is there any reason why instead of putting the turnbuckle at the control stick in center console.
Posted: Fri Jun 27, 2008 4:17 pm Post subject: Elevator cables modification |
makes no difference. you can put anywhere it is easiest for you to service the cable.
Juan Vega 3300
Posted: Fri Jun 27, 2008 4:49 pm Post subject: Elevator cables modification |
I put my turnbuckles on as: The down cable is on the upper part of the control yoke and thats easy to get to. The up cable is harder to get to so I put the turnbuckle on the elevator control horn at the tail. To adjust I remove the fiberglass fairing...
SW
Posted: Sat Jun 28, 2008 3:03 am Post subject: Elevator cables modification |
you can even put it close to the bottom hatch. just put it in the middle of the cable
n601xs(at)gmail.com Guest
Posted: Sat Jun 28, 2008 5:11 am Post subject: Elevator cables modification |
I installed my turnbuckles in the center console and had no difficulty adjusting the cables. The only challenge will be lockwiring the bottom turnbuckle and I plan to remove it from the control stick to perform that function. Other than for inspections I don't ever expect to have to access that turnbuckle. Any slight adjustments can be performed on the upper turnbuckle. I know several builders that have removable tail fairings and have installed the turnbuckle there, but mine is not. There is no reason the turnbuckle cannot be put in any of the locations suggested, but my experience is that in the center console it is easily inspected and has not been a problem.
Craig S.
N601XS, 601xl 0-235 lyc, preparing to install wings. Cushing Field, IL
