Engine Logbook
coop85(at)cableone.net
PostPosted: Thu Aug 16, 2007 3:35 am    Post subject: Engine Logbook Reply with quote
Here’s an odd question that I should know the answer to having built several airplanes prior to the RV-10 but can’t remember. Regarding documenting the annual conditional inspection the operating limitations specifically state what has to be written in the aircraft logbook. Is there anything specific that needs to be documented in the engine logbook?
Marcus
40286 – hard to believe it’s already been a year!
mritter509(at)msn.com
PostPosted: Thu Aug 16, 2007 5:21 am    Post subject: Engine Logbook Reply with quote
Here is my logbook entry:
"I certify that this aircraft has been inspected on 8/4/07 in accordance
with the scope and detail of Appendix D to part 43 and was found to be in a
condition for safe operation"
Mark
N410MR
Reply-To: rv10-list(at)matronics.com
Subject: Engine Logbook
Date: Thu, 16 Aug 2007 06:32:35 -0500
Here's an odd question that I should know the answer to having built
several
airplanes prior to the RV-10 but can't remember. Regarding documenting the
Marcus
40286 - hard to believe it's already been a year!
Now you can see trouble…before he arrives
http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_protection_0507
apilot2(at)gmail.com
PostPosted: Thu Aug 16, 2007 5:33 am    Post subject: Engine Logbook Reply with quote
The funny part is that various FSDOs had a running debate for years on this topic concerning TC aircraft. Some said only in airframe logbook, some said put 100 hour in engine and prop logs, some didn't care. Now there is specific guidance from HQ, that the statement has to be in the aircraft records, but not necessarily in any particular logbook. It sort of leads you to the airframe, simply because the other two may change.
On 8/16/07, Marcus Cooper <coop85(at)cableone.net (coop85(at)cableone.net)> wrote:[quote]
Here's an odd question that I should know the answer to having built several airplanes prior to the RV-10 but can't remember. Regarding documenting the annual conditional inspection the operating limitations specifically state what has to be written in the aircraft logbook. Is there anything specific that needs to be documented in the engine logbook?
Marcus
40286 – hard to believe it's already been a year!
= the many List utilities such as the Subscriptions page,
ronics.com/Navigator?RV10-List" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">
http://forums.matronics.com
james.k.hovis(at)gmail.co
PostPosted: Thu Aug 16, 2007 5:38 am    Post subject: Engine Logbook Reply with quote
On my old airplane, my IA would record the compression readings, any
engine AD compliance needed, and any other general maintenance and
repair work done to the engine. In the airframe log, basically the
same type information dealing with the airframe along with the engine
work so there are two records of work done to the engine.
Kevin H.
Mark
N410MR
>From: "Marcus Cooper" <coop85(at)cableone.net>
>To: <rv10-list(at)matronics.com>
>several
>Thanks,
>Marcus
Dave(at)AirCraftersLLC.co
PostPosted: Thu Aug 16, 2007 6:17 am    Post subject: Engine Logbook Reply with quote
Marcus,
My experience is that if you state that the "aircraft" has been inspected, that covers the engine too as far as being legal. The problem with that is you end up with a big, blank engine log which isn't of much value if you ever separate the engine from the airframe. So, for customers I generally write an entry for each logbook, including prop if there is one, telling what I did.
One philosophy is to document as little as necessary. Less ammo I suppose. I more or less go the other direction.
However...my own RV-10 logbook will essentially merge the flight and maintenance log. Pertinent engine/prop/avionics mx will get photocopied and filed separately. Hopefully the Excel format (attached) will allow me to easily transfer the original paper to the spreadsheet.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Thursday, August 16, 2007 4:33 AM
Marcus
N921AC_Log_Book_5-30-06.xls
 Filename:  N921AC_Log_Book_5-30-06.xls
 Filesize:  63 KB
 Downloaded:  428 Time(s)
PostPosted: Thu Aug 16, 2007 6:28 am    Post subject: Engine Logbook Reply with quote
Here's the logic for recording engine related data in the engine: On
my old AA-1A, it had a STC'd 160hp engine that came from a Cherokee.
There wasn't hardly any data in the logbook from when it was in the
Cherokee, especially AD compliance. (Note: I bought the airplane from
a couple guys who bought it to fix up and resell) When the previous
owners to me bought the bird (my IA was one of them), they went
through the engine and even tracked down the Cherokee it came out of
to be sure the list of AD's against that model engine had been
complied with. Keeping maintenence notes on the engine in the engine
log also helps track condition trends and if you ever swap out an
engine in the future, the new owner of the old engine will have a good
paper trail to track back to.
Kevin H.
there
> Thanks,
> Marcus
