tc1917(at)hughes.net Guest
Posted: Tue Aug 14, 2007 2:19 pm Post subject: motors |
Got a question to anyone who has done this or has the knowledge. I have
ordered a 912 UL to replace my 582 on my slingshot. I called the DAR who
originally inspected it for the airworthyness cert and he gave me some info
that I dont quite understand. Can anyone clarify for me the procedures for
changing this engine and prop? I know I must report the change and put all
the information as per the regs in the books but am not sure what the
paperwork is and who to. Going through the FARs on line is like trying to
read the serial numbers on transaxles while they pass by on the road. I
think I have to call FSDO tomorrow and ask for some info. anyone done this
recently?
also, just found out that there is a hornets next over certs for e-lsa
registering for their airworthiness cert. something about having to have it
inspected by the proper people for conditional inspection prior to having an
airworthiness inspection. an inspection before an inspection? the dar says
that this is something new and has to be done, another hoop for us to jump
through. man, they sure make it easy to register and stay legal, dont they?
can someone give me some information that a human can understand -- a human
going on 62 that has ingested too many gas fumes in his life. ted cowan,
alabama
planecrazzzy Guest
Posted: Tue Aug 14, 2007 2:31 pm Post subject: Re: motors |
Hi Ted,
As far as "I" know....If you have your "Repairmans Cert"
You just log it in the proper log books.... and fly "off" another 40 hrs in
your original "approved" test area....
( because the engine isn't certified )
Gotta Fly...
Mike & "Jaz" in MN
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Posted: Tue Aug 14, 2007 3:09 pm Post subject: Re: motors |
On the E-LSA item, I have an appointment tomorrow afternoon with the FSDO to inspect my FSII. I spoke with the inspector a couple of times on questions he had on my paperwork.
Nothing has been asked about the "Condition Report" and I completed the inspection and paperwork and my signature is on the document. I used the form I got from the EAA in the E-LSA Transition Kit.
The questions that have come up are:
Q: "How much flight time is on the bird?" A: More than 5 hours.
Q: Will you agree to this entry in your log book, "-----" (right out of the operating limitations published by the FAA) A: Yes
That is it. He said he did not see any other items. He also told me that this is all new and the instructions he has for guidance new as well. He has done some P Parachutes but this will be his first fixed wing unit.
I expect the actual inspection to be OK and tomorrow I will be legal.
jindoguy(at)gmail.com Guest
Posted: Tue Aug 14, 2007 4:01 pm Post subject: motors |
Ted, Clarify a few things for me if you would. Have you already been issued your experimental certificate and operation limitations?
Rick
On 8/14/07, tc1917 <tc1917(at)hughes.net (tc1917(at)hughes.net)> wrote:[quote]--> Kolb-List message posted by: "tc1917" < tc1917(at)hughes.net (tc1917(at)hughes.net)>
recently?
oops, should be operating limitations.
Rick
On 8/14/07, Richard Girard <jindoguy(at)gmail.com (jindoguy(at)gmail.com)> wrote: [quote]Ted, Clarify a few things for me if you would. Have you already been issued your experimental certificate and operation limitations?
Rick
On 8/14/07, tc1917 <tc1917(at)hughes.net (tc1917(at)hughes.net)> wrote: | Quote: | --> Kolb-List message posted by: "tc1917" < tc1917(at)hughes.net (tc1917(at)hughes.net)>
recently?
going on 62 that has ingested too many gas fumes in his life. ted cowan, http://www.matronics.com/Navigator?Kolb-List
takes on a whole new meaning
when you live at the airport. |
Rick Girard
"Ya'll drop on in"
Steven Green
Posted: Tue Aug 14, 2007 5:08 pm Post subject: motors |
Ted,
I made the switch from a 582 to 912S. I called the FSDO and asked the same
question. (This was before LSA) The best I recall it required the
following:
New weight and balance.
New data plate on the plane.
5 hour test period.
Logbook entry stating that the plane still flys. (or something like that)
This is just from memory so I have probably missed something.
I bet you will love the 912.
Steven
_________________ Steven Green |
Dennis.Kirby(at)kirtland. Guest
Posted: Wed Aug 15, 2007 7:58 am Post subject: motors |
"tc1917" asked: << I have ordered a 912 UL to replace my 582 ... Can
anyone clarify for me the procedures for changing this engine and prop?
Ted -
I went through the same process two years ago, when I swapped out the
Verner engine with a 912ul on my Mark-III.
Assuming your aircraft is registered as Experimental/Amateur-Built, the
FAA considers an engine change a "major" modification, and thus, you are
required to regress to your Phase-I flight test restrictions for a 5
hour period. This means you gotta fly solo and stay in your 25-mile
radius of your home airport for the new 5-hour flight test period.
After you verify that all is well with the new engine on your Slingshot,
you make the logbook entry stating so, and are then free to again
exercise all the regular privileges of your Phase-II Operating
Limitations.
You do everything (the modification, flight testing, logbook entries,
etc.). The FAA does not need to be involved.
p.s. - Good choice on the 912ul - you'll not regret your decision!
Dennis Kirby
Mark-III, 912ul
Cedar Crest, NM
