AW: Exhaust for Eci IOX-360 cold inuction
Rudolf.DALLINGER(at)kapsc
PostPosted: Tue Aug 07, 2007 11:16 am    Post subject: AW: Exhaust for Eci IOX-360 cold inuction Reply with quote
Thanks for the advise, I asked Larry but he does't have any muffler for the
4-pipe exhaust.
I think I will make a drial with the gross over, built for the M1B that vans
sells.
Rudi
RV8 QB 81943
Von: owner-rv8-list-server(at)matronics.com im Auftrag von Speed 3 Guy
Gesendet: Di 07.08.2007 14:14
An: rv8-list(at)matronics.com
Betreff: RE: Exhoust for Eci IOX-360 cold inuction
While at Oshkosh, I spoke with AeroSport Power about the ECI cold air induction.
It sound like there are not too many ECI cold air inductions flying yet. As far
as anyone at AeroSport knows, Larry Vetterman is the only common exhaust maker
that has worked with these. Larry does have mufflers available, at least for
some of his other systems. I would suggest you contact him or an exhaust
builder near you and see if they can use your engine to design a new, quiet,
exhaust for use with the ECI induction systems.
Guy Prevost SB 82273
[mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of DALLINGER Rudolf
Sent: Monday, August 06, 2007 3:14 AM
To: rv8-list(at)matronics.com
Subject: Exhoust for Eci IOX-360 cold inuction
Dear Listeners,
do anyone have experience obout Exhoust-Systems with an IOX-360 B1H1N (cold
intuction) from Eci with an RV8 S-Cowl?
The recommendation of Eci is an four-pipe-system von Lary Vetterman but this
exhoust-system seems to be quite loud.
I would like use the cross over-system. Which modifikations will be necessary?
Rudi
RV8 QB 81943
The information contained in this e-mail message is privileged and
confidential and is for the exclusive use of the addressee. The person
who receives this message and who is not the addressee, one of his
employees or an agent entitled to hand it over to the addressee, is
informed that he may not use, disclose or reproduce the contents thereof.
http://forums.matronics.com
