Kingfox tires
Goto page 1, 2  Next
lcfitt(at)sbcglobal.net
PostPosted: Tue Aug 07, 2007 9:34 am    Post subject: Kingfox tires Reply with quote
I bought a pair of the Nankang tires several years ago from a vendor other
than Mippi and had some issues with the bead leaking. I used the green
"Slime" for tubeless tires with good success. I used the version for
tubeless tires because I had heard that Slime was corrosive for alloy wheels
and assumed that the tubeless variety was OK. Wrong. when it came time to
replace the tires, there were pits all over the inner surface of the rims.
I was talking to a guy at an ATV place about the problem and he agreed that
Slime will damage alloy rims and commented that it was to be used only in
emergencies. I asked him what he used to seal the bead in difficult cases
and he didn't want to say, but I got him to admit that he uses RTV. I
didn't like that idea as I could just see adding to the difficulty of
breaking the bead by gluing the tires to the rims. In frustration, I did it
though as I got tired if having to top up the air every three days. The
leak would be very slow at first, but as the pressure gradually dropped, it
would proceed to a rush and then in a matter of a couple of hours it would
be from soft to dead flat. I applied it only to the outside bead as that
was the only place I could detect a leak by soaping.
All was great until I discovered that the tires still would go flat, but now
it would take a week or more to see the softening. I dealt with that with
the comeressed air tank then decided to finally add the RTV to the inside
bead - I only found that leak by removing the wheel and very carefully
soaping the whole tire. That took care of that by soap test, but breaking
the bead had somehow disturbed the cured RTV on the oustside, and now that
side leaked again - can of worms? Not really, rather than making bead
breakin harder, the RTV made breaking the bead much easier and after
cleaning up both sides, I wiped a thin layer of RTV with a gloved finger in
both bead areas and presto - no leaks for the first time in lots of years.
If you want to try this, use the RTV recommended by the factory for the fuel
tank installation. Some RTVs are corrosive to aluminum alloys.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 880 hrs.
akanka(at)kiamichiwb.org
PostPosted: Tue Aug 07, 2007 10:53 am    Post subject: Kingfox tires Reply with quote
An alternative to try is liquid detergent such as Ivory, or Palmolive, or
any brand you prefer. I've used it successfully on a variety of small
tubeless tires and car tires over the years. The stuff makes it easier to
seat the beads, dries and adds to the sealing effect, and don't leave any
residue to speak of, and what residue there is cleans up with water. I've
never noticed any corrosion or pitting of wheels when I've used it in the
past. Just use it straight from the bottle. Rub a good coat on with your
hand or use a paint brush to brush it on the tire bead, mount and inflate
the tire to maximum pressure to seat the bead, then reduce the pressure to
operational pressure.
John Hart
malpass-architect(at)comc
PostPosted: Tue Aug 07, 2007 4:20 pm    Post subject: Kingfox tires Reply with quote
What is the problem with just putting tubes in the tires.?
I once went into a swerve that was enough to break the seal, tire went flat,
and I had to rebuild my wheel pant.
I then put in tubes and now, no fear of that sort of thing again.
Bill Kitfox model III N793RK
Float Flyr
PostPosted: Tue Aug 07, 2007 4:53 pm    Post subject: Kingfox tires Reply with quote
With low pressure tires there isn't as much pressure holding the tire in place on the rim. If you have a fast solid touchdown it is possible to rotate the tire in the rim. If you have a tube in there you will cause the rim to cut off the air valve. Same result only possibly with both mains flat.
Just ask some of the guys using ATVs with low pressure tires... I'll bet they will advise against ever using a tube.
[img]cid:491015300(at)08082007-2ECE[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  577 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
clint_bazzill(at)hotmail.
PostPosted: Tue Aug 07, 2007 6:53 pm    Post subject: Kingfox tires Reply with quote
If you rotate the rim from a hard landing, I wouldn't worry about the rim
cutting the valve stem, you just lost all your air. My 2 cents worth.
Clint
Subject: RE: Kingfox tires
Date: Tue, 7 Aug 2007 22:23:13 -0230
flat.
Canada
Aerocet 1100s
<mailto:noelloveys(at)yahoo.ca> noelloveys(at)yahoo.ca
mikeperkins
PostPosted: Wed Aug 08, 2007 5:08 am    Post subject: Kingfox tires Reply with quote
This may seem like heresy to some folks, but I solved a leaking tire with an inner tube. It weighed less than a pound. [quote][b]
Float Flyr
PostPosted: Wed Aug 08, 2007 5:10 am    Post subject: Kingfox tires Reply with quote
it only has to rotate about 1/4 in to open the valve stem and you are right you would loose all your air. I have had the tires on my ATV move a lot more than that without losing an appreciable amount of air.
Check it out with the people who use those low pressure tires the most.
As you can see from my signature I don't spend a lot of time on wheels.
[img]cid:904135412(at)08082007-0FAA[/img]
Canada
Aerocet 1100s
[quote] --
 Filesize:  19.77 KB
 Viewed:  589 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
dave.wahlquist(at)ics.uwe
PostPosted: Wed Aug 08, 2007 5:29 am    Post subject: Kingfox tires Reply with quote
Just to add one more thing to this topic… You can use tubes with steel valve stems if you are worried about the tire and tube rotating and cutting a rubber stem. I think rotation is unlikely in a tire that is just coasting and not under power however.
Dave Wahlquist
Model III 582 under repair
Marshall,WI
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Perkins, Mike
Sent: Wednesday, August 08, 2007 8:06 AM
Subject: Re: Kitfox-List: Kingfox tires
Float Flyr
PostPosted: Wed Aug 08, 2007 6:20 am    Post subject: Kingfox tires Reply with quote
Don't forget your brakes. the steel valve stem could also be torn away from the tube. I think the best thing to do is to clean the rims as good as possible and seat the beads with a bit of soap. That being said, I now have a leaky tire on my ATV. Then again that tire has some pretty big slashes in the side walls that have been patched on the inside. I have a tube to put in it but was advised not to use it by guys who have a lot more experience with these machines than I have.
[img]cid:968581214(at)08082007-0FB1[/img]
Canada
Aerocet 1100s
 Filesize:  19.77 KB
 Viewed:  560 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Mnflyer
PostPosted: Wed Aug 08, 2007 6:26 am    Post subject: Re: Kingfox tires Reply with quote
Eight years of flying with inner tubes with all kinds of braking and have yet to rotate the tires much less cut a valve stem. Once the tires are seated on the bead for a time they are just about impossible to brake loose to change a tire much less rotate. Inner tubes ended my leaking tires 8 years ago and as posted they weigh less than a pound and hold air.
Comparing smooth rolling tires on a Kitfox to a ATV with heavy deep lugs under power and bigger brakes, is comparing apples to oranges.
GB
MNFlyer
Flying a HKS Kitfox III
PostPosted: Wed Aug 08, 2007 6:27 am    Post subject: Kingfox tires Reply with quote
I have read reports on the kitfox list (in the days of old) and the lancair
list of valve stems shearing. This is why I have avoided tubes.
Lowell Fitt
Cameron Park, CA
1998 870 hrs.l
Mark.Napier(at)sciatl.com
PostPosted: Wed Aug 08, 2007 7:59 am    Post subject: Kingfox tires Reply with quote
Hey Lowell,
How do you break the tire bead loose? When I needed to get the old pair
off my rims I had to take them to an ATV shop.
I mounted the new tires after many hours of polishing the rims to clean
up the seats. I bought some tire tools and a neighbor helped me put
them on.
Now my left tire looses air again and I'll bet there is some corrosion
in the bead seats again.
Thank you much,
Mark Napier
Time: 10:34:46 AM PST US
Subject: Kingfox tires
other
wheels
to
rims.
that
in
cases
did it
it
would
that
now
with
inside
breaking
that
in
years.
fuel
Lowell Fitt
Cameron Park, CA
1998 880 hrs.
- - - - - Appended by Scientific Atlanta, a Cisco company - - - - -
This e-mail and any attachments may contain information which is confidential,
proprietary, privileged or otherwise protected by law. The information is solely
intended for the named addressee (or a person responsible for delivering it to
the addressee). If you are not the intended recipient of this message, you are
not authorized to read, print, retain, copy or disseminate this message or any
part of it. If you have received this e-mail in error, please notify the sender
immediately by return e-mail and delete it from your computer.
PostPosted: Wed Aug 08, 2007 8:09 am    Post subject: Kingfox tires Reply with quote
Lowell,
I had tubes in my old tires and had no problem. When you install the tubes
you have to put in enough pressure to seal the tubless tires, then back off
on the air in the tube. If the tire rotates in the rim, you do have a
problem and its not the tubes fault. Clint
Subject: Re: Kingfox tires
Date: Wed, 8 Aug 2007 07:27:14 -0700
Lowell Fitt
Cameron Park, CA
1998 870 hrs.l
PostPosted: Wed Aug 08, 2007 9:59 am    Post subject: Kingfox tires Reply with quote
Hi, Mark,
I use the old drive on it with the front wheels of my truck trick. Put a
piece of old carpet under the wheel to prevent damage. It is a tough home
job, but it can be done. Sometimes I have my wife help me and she usuall
runs the other way when I have wheel in hand and call her name.
I once tried the small tire mount set, by Harbor freight and proceeded to
damage the hub. Going to an ATV shop sounds like a good idea, but I have
always been sort of a do-it-yourselfer.
Lowell Fitt
Cameron Park, CA
1998 880 hrs.
l.morris(at)tx.rr.com
PostPosted: Wed Aug 08, 2007 10:23 am    Post subject: Kingfox tires Reply with quote
Here's a thought: Use epoxy primer on the inside of your wheels,then you can use your tubeless tires and slime and not worry about corrosion.---Leon Morris/Classic4/50%/Flower Mound, TX
---- "Wahlquist wrote:
Just to add one more thing to this topic... You can use tubes with steel
Dave Wahlquist
Marshall,WI
Mike
Fox5flyer
PostPosted: Wed Aug 08, 2007 4:13 pm    Post subject: Kingfox tires Reply with quote
It's not heresy Mike. Probably the best way to go when one has a chronic leakage.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"If you don't read the newspaper you are
uninformed, if you do read
the newspaper you are misinformed."
Mark Twain
MichaelGibbs(at)cox.net
PostPosted: Thu Aug 09, 2007 8:03 am    Post subject: Kingfox tires Reply with quote
Lowell sez:
lancair list of valve stems shearing. This is why I have avoided
tubes.
My 1978 Piper Turbo Arrow III has inner tubes in all of her
tires--came that way from the factory, I believe. We've never had a
problem with valve stems or loss of air.
Mike G.
List Mom
Model IV-1200, N728KF
Phoenix, AZ
Float Flyr
PostPosted: Thu Aug 09, 2007 2:53 pm    Post subject: Kingfox tires Reply with quote
I have done it on ATV wheels by hand. Using an ATV shop is miles better if for speed if nothing else. However if you are going to do it by hand use round pry bars and you can wrap them with the handy man's secret weapon.... Duct tape. A bit of soapy water helps the tires slip off over the rims too. Just apply it after you break the bead down, a big job in itself.
[img]cid:837314922(at)09082007-1F80[/img]
Canada
Aerocet 1100s
[quote] -----Original Message-----
[mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of
Lowell Fitt
Sent: Wednesday, August 08, 2007 3:29 PM
Subject: Re: RE: Kingfox tires
--> Kitfox-List message posted by: "Lowell Fitt"
<lcfitt(at)sbcglobal.net>
Hi, Mark,
trick. Put a
a tough home
and she usuall
proceeded to
idea, but I have
Lowell Fitt
Cameron Park, CA
1998 880 hrs.
 Filesize:  19.77 KB
 Viewed:  564 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Thu Aug 09, 2007 3:53 pm    Post subject: Kingfox tires Reply with quote
Mike:
Are the tires on your Piper Turbo Arrow III low pressure?? That would make a difference. Obviously some of the guys on this list have used tubes successfully. I repeated what I had been told about low pressure tires. It's not an issue on floats...
Our old pal Dave Fisher, the swashbuckling, mud stomping flyer sent me a link to his page where he has a picture of his "custom" tire tool. I don't know exactly how it works but you can go here http://www.cfisher.com/kingfox.html for a look. Any one wh has been looking for a set of the King fox super tires can also contact him..... I think he could scare up a set. ;->
[img]cid:512214023(at)09082007-1F8E[/img]
Canada
Aerocet 1100s
[quote] --
 Filesize:  19.77 KB
 Viewed:  558 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Fri Aug 10, 2007 7:22 am    Post subject: Kingfox tires Reply with quote
Noel asks:
Recommended pressure for the mains is 30 psi and the nose wheel is 27
psi. Is that low pressure?
Mike G.
List Mom
Phoenix, AZ
Goto page 1, 2  Next
Page 1 of 2
