dhall(at)donka.net Guest
Posted: Sat Aug 04, 2007 1:06 pm Post subject: wing mating |
Having some doubt on getting the wings aligned.
I've got the wings in place with drift pins.
- i carefully leveled the fuse, longitudally and laterally.
- I suspended 3 plumb bobs each wing, out/mid/in.
- I stretched a line between the outboard bobs. The other 4 bobs were
behind the line. Suggests forward sweep.
- I restretched the line between the inboard bobs. The outboard bobs
were about 1/8-1/4" forward. Also suggests forward sweep.
This suggests I have forward sweep.
The problem is that I can't nudge the wings to take out the sweep. I
have two issues:
a) The rear spar is snug against the fuse, mostly interfering with the
round head rivet just above the attach point.
b) The flap is already very snug to the fuse.
In order to take as much as 1/4" sweep out, I calculated that I need
between 1/16" and 1/32" movement on the rear spar. Minor trimming
around the rivet and the inside edge of the spar would give me the
movement I need, but the flap fit is already so snug, nearly perfect, so
there's doubt. If I move the wing to take out fwd sweep, It looks like
I'll have to do some minor reshaping of the flap to avoid interference
with the fuse.
Questions:
- Anybody else find similar rivet or flap interference?
- Is it normal to have to tweak the flap fit along the fuse?
- Should I also be concerned about having to trim the rear spar?
Thought I was precise on the original cut, but I guess I could have been
off by a hair.
Man, it was a bear to get the wings in. I don't relish the thought of
taking them in/out for trimming and tweaking...
Don
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
rv8a2001(at)yahoo.com Guest
Posted: Sat Aug 04, 2007 2:16 pm Post subject: wing mating |
Install the wings with out the flaps and then trim the flaps to fit.......Worked great for me.......what do the instructions say?
Also a picture is worth a thousand words, and its been a few years so I dont remember any rivet problems.
Scott Bilinski
RV-8a
fvalarm(at)rapidnet.net Guest
Posted: Sat Aug 04, 2007 4:24 pm Post subject: wing mating |
Don,
I agree with Scott.
Also, double check with the plans and call Van's if there are still
questions. This is an important step. Primarily due to minimum edge
distance requirements on the rear spar. I seem to recall that some sweep
forward or aft (1/2'?) is permitted but not sure and I wanted to try and get
them perfect. So....
Assuming minimum edge distances are complied with, I trimmed to minimize the
sweep. I was able to bet the sweep to be zero. Originally I had left the
rear spars slightly long (about 1/16 as I recall). I then trimmed this to
clear a rivet head.
Five plum bobs worked for me. One from the tail area, one inboard, one
outboard on each wing, all hanging at the same time. (I drilled a 3/32 hole
in the center of the fuse near the last bulkhead to make a convenient place
to drop a plumb line from). I snapped a line on the floor under the wings
the full length of the wingspan. I then pulled each wing (only had to do
one) to get all the plumb bobs to point to the center of the line. The
outboard bobs hung from the last rivet line. This was important because
where these bobs intersected the snapped line, I made a mark on the floor.
I then measured with a long tape to the bob hanging in the tail. When the
left and right triangulations agreed, I knew I had no sweep and straight
wings.
This was on a RV7A but I think it would be the same on a 8.
Good luck
Bevan
pgroell(at)numericable.co Guest
Posted: Sun Aug 05, 2007 12:18 am Post subject: wing mating |
Hello,
About the rear spar and rivet interference have a look at this page, about
2/3 down.
http://www.jeffsrv-7a.com/WINGS/05-11-20.htm
Pascal
-----Message d'origine-----
De : owner-rv7-list-server(at)matronics.com
[mailto:owner-rv7-list-server(at)matronics.com] De la part de dhall(at)donka.net
Envoyé : samedi 4 août 2007 23:06
À : rv7-list(at)matronics.com
Objet : wing mating
have two issues:
with the fuse.
Questions:
off by a hair.
Don
colfearnow(at)earthlink.n Guest
Posted: Sun Aug 05, 2007 4:17 am Post subject: wing mating |
wing mating,
DHall,
I had the same problem...the wing rear spar was too tight. Van's told me
that a 1/4 to 1/2 is not a big concern...but I wanted zero, or at least
close to it. I had to trim the two mating surfaces to get the sweep to
zero; go slooowwwly and be conservative and it will be perfect.
Remove the flap first than work your sweep. I had to trip my flap skin
quite a bit to make it clear and look even (on both sides). Again, be
conservative and take your time.
Ron F.
-7A, Canopy/baffling/cowling
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sun Aug 05, 2007 6:08 am Post subject: wing mating |
I went with the Van's method... I had a 1/8" sweep and paid attention to the
Van's "get real" admonishment, mostly because I'm not an engineer and they
are. But I can see where people strive for perfection. The question I have
in this regard is what IS the flying difference between, say, 0 sweep and
1/45" sweep.
One warning to all -- The "window" (i.e. the area) to drill the bolt hole
in the rear spar fork is MUCH smaller than most people think. Be very
careful about how much you remove in that area.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
wgill10(at)comcast.net Guest
Posted: Sun Aug 05, 2007 9:23 am Post subject: wing mating |
The "window" is indeed very small. IIRC, I had a window 1/16" wide X
5/32" tall.
