baremetl(at)gvtc.com Guest
Posted: Sat Aug 18, 2007 5:41 pm Post subject: LSE Direct crank vs. Hall effect |
After nearly 1400 hrs.and 4 mag failures (Slick), I am considering an LSE unit to replace the right mag. I realize that the direct crank sensor is less expensive and that the Hall effect sensor that mounts in the old mag position is simpler to install. Ignoring the cost difference and initial installation difference, is there any other reason to pick one over the other? I am looking for comments on reliability of one sensor vs. the other and any other pertinent information.
Ivan Haecker -4 1381 hrs. S. Cen. TX
ps 3 failed coils and 1 failed condensor. And yes I used blast tubes (after the 1st failure!)
| | - The Matronics RV4-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV4-List |
smokyray(at)yahoo.com Guest
Posted: Mon Aug 20, 2007 6:36 pm Post subject: LSE Direct crank vs. Hall effect |
1500 hours on my Electroair ignition...give them a call.
www.electroair.net
Rob Ray
"H.Ivan Haecker" <baremetl(at)gvtc.com> wrote:[quote] After nearly 1400 hrs.and 4 mag failures (Slick), I am considering an LSE unit to replace the right mag. I realize that the direct crank sensor is less expensive and that the Hall effect sensor that mounts in the old mag position is simpler to install. Ignoring the cost difference and initial installation difference, is there any other reason to pick one over the other? I am looking for comments on reliability of one sensor vs. the other and any other pertinent information.
