| gus.fraser(at)gs.com Guest
				|  Posted: Tue Feb 14, 2006 12:51 pm    Post subject: Yak-List:[feedback] 4340 Alloy steel sheet needed. [feedback |   |
				| Well folks I have had great help in my search. Scott,  thanks for introducing me to the truly remarkable www.matweb.com , all and more that you  need to know about all kinds of materials. The best bit is the search engine. I  put in the specific properties that I needed for the 4340 and it gave me a  recipe for 4140 that does the same thing, awesome.
 Also I found the following http://www.russelmetals.com/pdf/english/service/pdf_catalogue/Section_14_-_Weights_and_Useful_Data.pdf which  is a 26 page guide great to keep in the hanger.
 Suggestions on the best way to heat to just over 1575  deg F welcome.
 Gus
 [quote]         From: owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Fraser,    Gus
 Sent: Tuesday, February 14, 2006 1:18 PM
 To:    'yak-list(at)matronics.com'
 Subject: RE: 4340 Alloy steel    sheet needed.
 Dennis,
 Thanks for that I called them yesterday and they only    have larger sizes available. .1 and up. For reference this is the steel used    for undercarriage units also.
 Thanks again
 Gus
 [quote]               From: owner-yak-list-server(at)matronics.com      [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis      Savarese
 Sent: Tuesday, February 14, 2006 12:57 PM
 To:      yak-list(at)matronics.com
 Subject: Re: 4340 Alloy steel      sheet needed.
 See if these folks can help.
 http://www.advancedglobalmaterials.com/4130-4340sheet.asp
 Dennis
 Alloy Steels
 4340Mod
 4620
 4720
 6150
 8620
 8740
 9310
 52100
 H11
 HY60 -            100
 D6AC
 HP 9 -            4 -  20
 300M
 HP 9 -            4 - 30
 D6-AC
 HY - TUF
 Maxel 3            1/2
 Maraging  250,  300,             350
 Aircraft Quality & Vacuum            Melted
 *All materials            available  in the following:
 Plate,            Sheet, Rod, Bar, Tubing, Pipe, Wire, Forgings, Custom Shapes &            Sizes
 [quote]       ---
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
