spraying UV Smoothprime
CJohnston(at)popsound.com
PostPosted: Wed Jul 25, 2007 2:06 pm    Post subject: spraying UV Smoothprime Reply with quote
Hey all –
Could someone give me some tips on spraying UV smoothprime? I can’t seem to get consistent results with my spray gun. It just starts spitting and not wanting to come out right. I thinned the paint like the instructions say, and I can’t seem to make it go right. I’d try to roll it on like it says, but it’s the interior of the cabin top, and I’ve got the overhead console in there which would make that hard. Any thoughts?
cj
#40410
fuse/finishing
www.perfectlygoodairplane.net
indigoonlatigo(at)msn.com
PostPosted: Wed Jul 25, 2007 2:54 pm    Post subject: spraying UV Smoothprime Reply with quote
Use zolatone and forget all the prep of the interior surfaces...you are a
glutten for punishment.
Just a thought?
JOhn G.
Reply-To: rv10-list(at)matronics.com
Subject: spraying UV Smoothprime
Date: Wed, 25 Jul 2007 14:56:36 -0700
Hey all -
Could someone give me some tips on spraying UV smoothprime? I can't
the instructions say, and I can't seem to make it go right. I'd try to
roll it on like it says, but it's the interior of the cabin top, and
I've got the overhead console in there which would make that hard. Any
thoughts?
cj
#40410
fuse/finishing
seipel(at)seznam.cz
PostPosted: Wed Jul 25, 2007 4:02 pm    Post subject: spraying UV Smoothprime Reply with quote
Did you run it through a paint filter? If you didn't, you're probably
getting chunks which are clogging the gun. I was surprised at how many
chunks of stuff that the paint filter caught.
PJ Seipel
RV-10 #40032
Chris Johnston wrote:
Hey all –
thoughts?
cj
#40410
fuse/finishing
Deems Davis
PostPosted: Thu Jul 26, 2007 5:54 am    Post subject: spraying UV Smoothprime Reply with quote
Spraying Smoothprime is a challenge for me, but well worth it! I have
found that by following the dilution instructions on the can/pail that
it's too thick, and I have the same results you're seeing, so I dilute
it until I can get a better spray out, I don't have a ratio to use, I
just keep adding small amounts of water until I can get a 'wet' spray
pattern. the unfortunate side effect of that is that, for me, when I get
it this thin, unless I'm EXTREMELY careful I will inevitably end up with
a run, or two when shooting on a vertical surface. The runs sand out
fairly easily though so aren't really much of a problem. Shooting
several VERY light coats vs a couple of heavy coats works better as
well. Another thing I've noticed is that it seems to 'clog' a bit in the
gun, and that by placing a finger over the nozzle ,temporarily plugging
it, while pulling the trigger seems to help to clear any clogs that seem
to form in the gun while waiting for the coat you just sprayed to dry
enough to shoot the next coat. (be careful not to allow a buildup on
primer on the nozzle.)
Deems Davis # 406
'Its all done ....It's just not put together yet!'
http://deemsrv10.com/
Hey all –
thoughts?
cj
#40410
fuse/finishing
jwt(at)roadmapscoaching.c
PostPosted: Thu Jul 26, 2007 5:57 am    Post subject: spraying UV Smoothprime Reply with quote
I have had great luck spraying Smoothprime with my Harbor Freight HVLP gun. I thinned per instructions and filtered. I sprayed several thin coats.
I did have problems with another touch up gun but I think it was dirty. Rolling wastes a lot of material since it leaves a lot of texture. I also bush and squeegee it to fill low spots and holes.
I would not waste time using it on the inside if you are going to cover with headliner. I really like the stuff on the outside canopy and cowls.
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Paint prep, interior, and LOTS of little stuff
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
Sent: Wednesday, July 25, 2007 5:57 PM
Hey all –
cj
#40410
fuse/finishing
No virus found in this incoming message. size=2>Version: 7.5.476 /
7/20/2007 4:39 PM
PostPosted: Thu Jul 26, 2007 8:21 am    Post subject: spraying UV Smoothprime Reply with quote
Aaahh. Is there something that’s not a “filler primer” that can be sprayed on as primer over sanded epoxy? I am (I think) going to cover with headliner, but I’d like to seal the sanded epoxy with something before I cover it. is there something like Akzo for glass?
cj
#40410
fuse/finishing
PostPosted: Thu Jul 26, 2007 9:31 am    Post subject: spraying UV Smoothprime Reply with quote
No reason to seal sanded epoxy, it in itself is a solid, non absorbant
material...unless you penetrated the glass cloth.
You are a glutten for punishment! As if we didn't have enough work to begin
with.
John G.
[quote]From: "Chris Johnston" <CJohnston(at)popsound.com>
Subject: RE: spraying UV Smoothprime
Date: Thu, 26 Jul 2007 09:18:39 -0700
Aaahh. Is there something that's not a "filler primer" that can be
with headliner, but I'd like to seal the sanded epoxy with something
cj
#40410
fuse/finishing
robin1(at)mrmoisture.com
PostPosted: Thu Jul 26, 2007 9:38 am    Post subject: spraying UV Smoothprime Reply with quote
John,
I went to the Zolatone website and I am still confused as to
what it is exactly. Can you please describe what Zolatone is and how &
where you used it on a -10?
I am thinking of not using a head liner (I have a overhead
console) and was considering just painting the upper cabin.
Thanks in advance,
Robin
Ray.R.Doerr(at)sprint.com
PostPosted: Thu Jul 26, 2007 10:13 am    Post subject: spraying UV Smoothprime Reply with quote
Zolatone is a splatter paint. I used it on my interior and it looks great on the ceiling because you don't have to worry about how to trim the edges of a headliner. I just prep'ed the top first by making the center joint and other areas real smooth. I have have numerous compliments on how nice it looks.
Thank You
Ray Doerr
40250
N519RV
Flying
PostPosted: Thu Jul 26, 2007 10:20 am    Post subject: spraying UV Smoothprime Reply with quote
Here are some pictures of my top. You can see that I filled all the voids around the rear windows so it was all smooth and then I sprayed the Zolatone. Zolatone requires a large tip for your gun so the little balls of paint don't explode until the hit the surface being sprayed and not at the tip of the gun.
Thank You
Ray Doerr
40250
N519RV
 Filesize:  120.26 KB
 Viewed:  239 Time(s)
 Filesize:  143.79 KB
 Viewed:  241 Time(s)
 Filesize:  121.28 KB
 Viewed:  243 Time(s)
PostPosted: Thu Jul 26, 2007 1:21 pm    Post subject: spraying UV Smoothprime Reply with quote
Zolatone is a waterbassed paint which provides a textured surface and
appearence. In the end it looks like granite. Because it is textured, one
only needs to remove the worst of the imperfections in the surface to be
coverred. It is a real time saver...it also looks like fabric with out all
the hassle of cutting and glueing..
Tip---Once the cabin top is all drilled and the aluminum backing strips area
drilled and de burred, one can glue the aluminum backing strips to the cabin
top and paint the entire interior before rivetting it in.
I know how many of you hate sanding out all those imperfections in that high
quality cabin top.
Maybe I'll send some photos later.
JOhn G.
Date: Thu, 26 Jul 2007 13:34:32 -0400
John,
Thanks in advance,
Robin
PostPosted: Thu Jul 26, 2007 5:10 pm    Post subject: spraying UV Smoothprime Reply with quote
Thank you and photos would be GREAT!
Can this be glossy white and still textured?
Robin
PostPosted: Thu Jul 26, 2007 7:18 pm    Post subject: spraying UV Smoothprime Reply with quote
Probably the best sealer would be just epoxy thinned 50% with Acetone (Vans sealer approach).
John Testement
40321
Richmond, VA
Sent: Thursday, July 26, 2007 12:19 PM
cj
#40410
fuse/finishing
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
Sent: Thursday, July 26, 2007 6:56 AM
John Testement
40321
Richmond, VA
Hey all –
cj
#40410
fuse/finishing
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com
7/20/2007 4:39 PM
- The RV10-List Email Forum -
1No virus found in this incoming message. size=2>Version: 7.5.476 /
7/20/2007 4:39 PM
