Icom A200-Help! (errata of first draft wiring diagrams)
gmcjetpilot(at)yahoo.com
PostPosted: Mon Feb 13, 2006 9:48 am    Post subject: Icom A200-Help! (errata of first draft wiring diagrams) Reply with quote
Basic ICOM A200 wiring (corrected). Forgot a jumper in the first draft. Also shown is my interpretation of how to wire the "HOT" mic intercom built into the ICOM. I have heard from two folks that used the ICOM internal intercom. It works but is low on volumn, and it was suggest even a cheap Flightcom or similar low cost VOX intercom would be better.
http://img486.imageshack.us/img486/8466/icoma2004lh.jpg
Below is my two ICOM's with no audio panel idea's. I show three ways to wire. Disclaimer is I never wired this up before, but think it will work fine. I have great memories of my OLD Piper Apache with two King KX170's that did not have an audio panel. It just had a switch to select the transmitter. The ADF was wired thru one of the KX170s aux input ( I think) and individual volumn control was used to listen or silence the radio/nav of choice.
The mixer is a common electronic kit that takes 3 or 4 inputs and mixes it thru a preamp to one output.
http://img486.imageshack.us/img486/3088/icomblock5xg.jpg
George
