Weight & Balance
steve2(at)sover.net
PostPosted: Wed Jul 18, 2007 12:36 pm    Post subject: Weight & Balance Reply with quote
Folks,
Before I go and reinvent the wheel, has anyone built a 500 series, or
Commander specific spreadsheet I can adapt?
If not, a good generic sheet would work just fine as a beginning point. I'll
compare the end results with numerous loading scenarios we have calculated.
Steve
cloudcraft(at)aol.com
PostPosted: Wed Jul 18, 2007 6:14 pm    Post subject: Weight & Balance Reply with quote
Steve,
When I was at Inter Island Air, I developed an (almost) "one sheet does all" Weight & Balance / Manifest/ Dispatch sheet for FAR 135 purposes.
It is not a spread sheet but the arms are there and one can do simple math on the go -- and have the C.G. envelope tables right there.
I'm on a trip for a few days; when I get home I'll upload the template for the 500 A/B/U/S.
Wing Commander Gordon
aquadiver99(at)yahoo.com
PostPosted: Wed Jul 18, 2007 7:59 pm    Post subject: Weight & Balance Reply with quote
WCG, I lok fwd to seeing the sheets!
Donnie Rose
205/492-8444
DavidFitzgerald(at)bigpon
PostPosted: Wed Jul 18, 2007 8:05 pm    Post subject: Weight & Balance Reply with quote
I don’t know if attachments work but this is a homemade one
Cheers
Dr David Fitzgerald
BMedSci(Hons) MBBS(Hons) ACCAM DipAvMed(Otago)
CASA Medical Officer
Designated Aviation Medical Examiner and Commercial Pilot, Tasair
Zinifex Hobart Smelter and Rosebery Mine Medical Officer
Registrar in Occupational Medicine
DavidFitzgerald(at)bigpond.com (DavidFitzgerald(at)bigpond.com)
mob 0438 312973
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Donnie Rose
Sent: Thursday, July 19, 2007 1:58 PM
Subject: Re: Commander-List: Weight & Balance
[b]Donnie Rose [/b]
[b][b]205/492-8444
[/b][/b]
----- Original Message ----
From: "cloudcraft(at)aol.com" <cloudcraft(at)aol.com>
Sent: Wednesday, July 18, 2007 9:13:51 PM
Subject: Re: Weight & Balance
Steve,
-----Original Message-----
Sent: Wed, 18 Jul 2007 1:24 pm
Subject: Weight & Balance
--> Commander-List message posted by: "Steve at Col-East" <steve2(at)sover.net (steve2(at)sover.net)>
Folks,
Before I go and reinvent the wheel, has anyone built a 500 series, or Commander specific spreadsheet I can adapt?
If not, a good generic sheet would work just fine as a beginning point. I'll compare the end results with numerous loading scenarios we have calculated.
Steve
Join our Network Research Panel today!
EXCLOAD&BALANCE2.xls
 Filename:  EXCLOAD&BALANCE2.xls
 Filesize:  46.5 KB
 Downloaded:  477 Time(s)
PostPosted: Wed Jul 18, 2007 8:06 pm    Post subject: Weight & Balance Reply with quote
Donnie, Steve, All,
I'll be uploading a rather clumsy Word.doc with a bunch of too-high density .bmp images embedded. I made these back in 1995 and my equipment (brains and computer gear) was not used as efficiently as it could have been.
Still, they'll be fairly universal across platforms and will be easy to edit/customize.
steve2(at)sover.net
PostPosted: Thu Jul 19, 2007 2:35 am    Post subject: Weight & Balance Reply with quote
David,
The attachment worked fine. This is a really nice sheet! I probably wouldn't have built the graphics on my own, so I'm glad to have them. Thanks for sharing it.......
I look forward to getting Gordon's work so I can rejigger it for our use here.
Thanks guys,
Steve
PostPosted: Thu Jul 19, 2007 6:58 am    Post subject: Weight & Balance Reply with quote
Hey Steve, can you please re-send, I didn't get the attachment.
N69PT
Donnie Rose
205/492-8444
steve2(at)sover.net
PostPosted: Thu Jul 19, 2007 7:14 am    Post subject: Weight & Balance Reply with quote
Donnie,
That spreadsheet was sent courtesy of David down-under. I'll send the copy I received to your Yahoo mail. I'm tweaking it to read in lbs and inches...... If you want one when I'm done I'll send it along.....
Steve
PostPosted: Thu Jul 19, 2007 8:21 am    Post subject: Weight & Balance Reply with quote
Yes Steve, I would like a tweaked copy, my metric is a little rusty!
Donnie Rose
205/492-8444
steve2(at)sover.net
PostPosted: Mon Jul 23, 2007 10:28 am    Post subject: Weight & Balance Reply with quote
Well I goofed around a little with Excel and came up with a simplified W&B spreadsheet based off the original from David.
Give it a test run and see if it works.
I did find that with our Commander, there are loading scenarios that have us go too far forward in C.G with small quantities of fuel just like Cmd Gordon said. I'll have to stop poking fun at our cameraman's weight, because we apparently need the ballast. I did a couple test runs with generic values of a Commander that doesn't have 300 pounds of gear in the middle row, and it is harder to get a 500 out of sorts.
The sheet is generic enough to where it should be easily modified to fit many models. The sheet is 'Protected' so the fumble-fingered among us can't hurt it, but there is no password so anyone can modify the cells. Just go up to Tools, Protection, to protect and unprotect sheet.
So enter you empty weight and C.G. in blue once.
Then just modify yellow cells. It should print out nice also......
For the spreadsheet challenged, I could enter stuff for you, but really, it's easy. If you haven't messed with these things before, try it. They're neat..... I'm just scratching the surface, so if any of you fellows are better, go ahead and make this a better thing......
Hope the attachment makes it.
Steve
Generic_Commander_Weight_&_Balance_DRAFT.xls
 Filename:  Generic_Commander_Weight_&_Balance_DRAFT.xls
 Filesize:  37 KB
 Downloaded:  464 Time(s)
Jim Addington
PostPosted: Tue Jul 24, 2007 11:41 am    Post subject: Weight & Balance Reply with quote
Donnie,
I would like a copy in lbs and inches also.
Jim Addington
N444BD
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Steve at Col-East
Sent: Thursday, July 19, 2007 10:10 AM
Donnie,
Steve
wjrhamilton(at)optusnet.c
PostPosted: Wed Jul 25, 2007 3:50 pm    Post subject: Weight & Balance Reply with quote
Donnie,
Likewise.
Bill Hamilton
<wjrhamilton(at)optusnet.com.au>
At 05:39 AM 25/07/2007, you wrote:
[quote] Donnie,
Jim Addington
N444BD
From: owner-commander-list-server(at)matronics.com [ mailto:owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com)] On Behalf Of Steve at Col-East
Donnie,
Steve
PostPosted: Wed Jul 25, 2007 4:54 pm    Post subject: Weight & Balance Reply with quote
Cheers back at you big guy!
By the way, has anyone seen an itenerary for the fly-in?
Donnie Rose
205/492-8444
nico(at)cybersuperstore.c
PostPosted: Wed Jul 25, 2007 5:17 pm    Post subject: Weight & Balance Reply with quote
Check it out on the website, Donnie.
www.aerocommander.com
Nico
Sent: Wednesday, July 25, 2007 5:54 PM
[b]Donnie Rose [/b]
[b][b]205/492-8444
[/b][/b]
PostPosted: Wed Jul 25, 2007 5:52 pm    Post subject: Weight & Balance Reply with quote
Thanks Nico, my naive arse didn't know there was such!
Donnie Rose
205/492-8444
PostPosted: Wed Jul 25, 2007 6:12 pm    Post subject: Weight & Balance Reply with quote
Hey Nico, I was about to register but it has a slot for "member", how do I become one?
By the way, I will have empty seats if anyone needs a ride.
Donnie Rose
205/492-8444
PostPosted: Wed Jul 25, 2007 8:59 pm    Post subject: Weight & Balance Reply with quote
Jim Metzger (Capt Jimbob) will pick this up and take care of it for you.
Nico
Sent: Wednesday, July 25, 2007 7:10 PM
[b]Donnie Rose [/b]
[b][b]205/492-8444
[/b][/b]
Sent: Wednesday, July 25, 2007 8:17:13 PM
Subject: RE: Weight & Balance
Nico
[b]Donnie Rose [/b]
[b][b]205/492-8444
[/b][/b]
kamala(at)MSN.COM
PostPosted: Thu Jul 26, 2007 3:51 am    Post subject: Weight & Balance Reply with quote
all, we could make hand outs at the fly in of the w & b info and any others of interest. mason
[quote] From: nico(at)cybersuperstore.com
Date: Wed, 25 Jul 2007 21:58:42 -0700
.ExternalClass .EC_shape {;} .ExternalClass EC__filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} .ExternalClass EC__filtered {panose-1:0 0 0 0 0 0 0 0 0 0;} .ExternalClass EC__filtered {;} .ExternalClass h4 {margin-right:0in;margin-bottom:3.0pt;margin-left:.25in;font-size:11.0pt;font-family:'Times New Roman';font-weight:normal;} .ExternalClass EC_a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass EC_a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.emailstyle19 {font-family:Arial;color:navy;} .ExternalClass EC_span.EmailStyle20 {font-family:Arial;color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Nico
[b]Donnie Rose [/b]
[b][b]205/492-8444
[/b][/b]
steve2(at)sover.net
PostPosted: Thu Jul 26, 2007 5:51 am    Post subject: Weight & Balance Reply with quote
Fellers,
I'm glad to see the W&B spreadhseet taking on a life of its own. I found the results very interesting.
Just keep in mind I wrote it up as a quick draft after swiping stuff from the TasAir sheet. But it isn't exactly the same sheet anymore.
It isn't a complicated sheet, but before this gets a lot of circulation, how about reporting back after you've verified that it's producing the results you expect. That way I can tweak it if need be before finalizing.
I had also though about trying to integrate the TO&L distances calculator, and or a data entry page for multiple models.
Steve
PostPosted: Thu Jul 26, 2007 6:39 am    Post subject: Weight & Balance Reply with quote
Donnie Rose
205/492-8444
