Vince Frazier
				 Posted: Tue Jul 17, 2007 5:54 am    Post subject: Rocket jacking |
				Rocket Jacking.
 No, not a terrorist attack, or a porn site... but how to raise your
 Rocket safely.
 First let me say, don't you guys ever read my website?  You are truly
 missing out on the world's foremost source of Rocket info, the oldest
 Rocket site out there and still the best.  Prove me wrong.
 I had a worm clamp like Tom Martin describes fail on me while raising
 the plane.  It does work, but be sure to use a quality clamp if you do.
 This was during the gear leg shortening described on my site... so I was
 asking a lot of the little clamp.
 Here's a couple shots of a pair of ordinary wing jacks being used under
 the motor mount. I made a couple of simple saddle pads that fit the top
 of the jacks and nested under the lower mount tube.  This is a very
 sturdy, safe way to lift your bird since it keeps the weight right next
 to the gear... where it is normally found anyway!
 http://www.vincesrocket.com/checking%20toe.jpg  jack setup
 http://www.vincesrocket.com/jacking%20the%20plane.jpg upper position
 http://www.vincesrocket.com/jack%20pad.jpg jack pad
 This is an EASY and STRONG jacking method.  Weld a plate to an exhaust
 clamp and stick a jack under it.  I can almost hear the whining already,
 "Ew, ew, won't that scratch my axle socket paint?"  No, not if you're
 careful.  And it's much better than punching a hole in your wing if
 you're tempted to use the wing jacks under the wing.  I've used this
 setup THREE times on my bird so far, and the paint is fine.  But, touch
 up the paint if you aren't so lucky. 'nuf said.
 http://www.vincesrocket.com/jacking%20the%20gear%20leg.jpg exhaust clamp
 jacking device
 I'm not a big fan of using straps on the engine mount, although I did it
 several times during construction when the total weight of the plane was
 hundreds of pounds lower.  Just don't use the lifting eye on the engine
 unless you want to risk cracking the case. Ouch.
 Vince
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
  _________________ Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
