dmasys(at)cox.net Guest
Posted: Thu Jul 12, 2007 3:31 am Post subject: Help with EIS fuel sender configuration |
I have the Vans fuel senders hooked to Aux inputs on my GRT Engine Information System, but not having much luck getting the proper fuel quantity to display using the instructions from GRT. Does anybody happen to have the Scale Factor (AuxSF) and Offset (OFF) values they used for their senders, and can confirm that reverse rather than forward sensing is used? Thanks in advance for any help with this.
DAR inspection this weekend...
-Dan Masys
N104LD
coop85(at)cableone.net Guest
Posted: Thu Jul 12, 2007 3:14 pm Post subject: Help with EIS fuel sender configuration |
Dan,
Attached is a file I have on my EIS settings, hope it helps (I stole it
from Tim in case it looks familiar to anyone). One huge caveat, I can't be
sure if anything was changed since I made this list. I'll double check it
the next time I go out, but I'm not sure when that will be.
Just in case it doesn't work I've sent it private mail as well but anyone on
the list is free to reference it.
Marcus
40286
EIS_settings_-_N585MR.doc |
39 KB |
275 Time(s) |
