Wiring issues
rlnelson5
PostPosted: Sat Feb 11, 2006 9:05 pm    Post subject: Wiring issues Reply with quote
Hello
Redoing my lower dash panel.
1 I have a Whalen strobe powerpack that can handle either 1,2,3 or 4 strobes. It is 14v 7a unit . I have 2 wingtip , 1 tail and 1 red strobe/ beacon.
My question is if I could use a [ 2-10 ?] switch to control this strobe power unit and have the red beacon turn on the middle switch position and then add the other 3 strobes at the top switch position?
If that would not do it is there some other arrangment to do it?
2 I have the B + C instrament lighting dimmer setup .
I have Inst. lights, couple of post lights Radio lights ,Lower dash panel lights , and 2 over the shoulder lights. I have a cabin ovhd light as well.
I am using Fiber light units on most instraments and on the lower dash. The lower dash units are a long fiber optic strip that has lettering on them to label the lower dash panel items.
How should I handle this whole setup?
I only have one dimmer pot .
Do I need some type of rotary switch?
Regular switches or wire the ovhd to a seperate switch? ? wire them all together?
Any ideas would be helfull
thanks l
Bret Smith
PostPosted: Sat Feb 11, 2006 9:47 pm    Post subject: Wiring issues Reply with quote
"The lower dash units are a long fiber optic strip that has lettering on
them to label the lower dash panel items."
Do you have a picture of this? Manufacturer?
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
rlnelson5
PostPosted: Sat Feb 11, 2006 10:01 pm    Post subject: Re: Wiring issues Reply with quote
Sure , look in the Aircraft Spruce catalog. Made by Fiberlite. I have the 2004-5 version , on page 423 . It is called Illuminated Labeling
