Crimp or Solder ?
john(at)totten.com
PostPosted: Sat Feb 11, 2006 5:54 pm    Post subject: Crimp or Solder ? Reply with quote
Can anyone tell me the standard for aircraft wiring - Crimp
or Solder?
aadamson(at)highrf.com
PostPosted: Sat Feb 11, 2006 6:37 pm    Post subject: Crimp or Solder ? Reply with quote
As long as you use a good crimper (sheesh volumes have been written about
that on this list), a "gas tight" crimp is as good as a solder and in some
ways better.
Less time consuming and wont wick solder farther into the wire than is need
leaving an area for the wire to break from vibration.
My vote, crimp and never look back, but use a *good* crimper and die set
made for the task
Alan
nuckollsr(at)cox.net
PostPosted: Sun Feb 12, 2006 2:32 pm    Post subject: Crimp or Solder ? Reply with quote
or Solder?
See:
http://aeroelectric.com/articles/Crimp_vs_Solder_and_other_nagging_questions.pdf
for an updated article on this and other issues.
