Don Owens
Joined: 17 Jan 2006 Posts: 24 Location: North Central Washington
Posted: Sun Jul 01, 2007 8:06 am Post subject: [Spam] Soldering to copper foil tape |
Hi Ralph,
I don't know about the article, but I have soldered a lot of copper foil
tape. Actually that is what the stuff is made for. It's used for soldering
leaded glass window pieces together - stained glass work.
I once put a spider-web of copper foil tape on a plastic fuel tank (to
collect static electricity) and soldered ground wires to it. Anyway, it is
the easiest stuff there is to solder.
Don Owens
<recapen(at)earthlink.net>
Was there an article on a recommended way to do this?
I vaguely remember a discussion on this topic.
I'd rather do it right than again!
5:32 PM
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
tim2542(at)sbcglobal.net Guest
Posted: Sun Jul 01, 2007 8:53 am Post subject: [Spam] Soldering to copper foil tape |
You want to use the 63/37 (60/40 is ok) rosin core stuff, heat the work not
the solder. The finished joint should be shinny, one or two practice runs
and you will be an expert.
Tim Andres
j.rippengal(at)cytanet.co Guest
Posted: Sun Jul 01, 2007 10:17 am Post subject: [Spam] Soldering to copper foil tape |
Ralph,
Before you get down to actually soldering the wire or whatever to the tape
think about how you will anchor the whole lot so that it cannot be torn
apart easily. Copper tape is very delicate stuff.
When you have cleaned (very important, no grease or oxidation) and anchored
the tape and the bit you are going to solder to it place the end of a coil
of resin cored 60/40 solder (the stuff amateur electronics - Radio Shack -
people use) on top of the junction and then place a hot soldering iron on
top of the solder. Make sure the solder flows quickly and evenly leaving a
shiny surface (not matt or grainy). If you use a standard electric soldering
iron and leave it on for at least five minutes it will be at the correct
temperature.
If it is a big fat tape with a big fat wire to be joined to it then use a
big fat soldering iron.
John.
