fiberglass panel
icubob(at)newnorth.net
PostPosted: Wed Jan 04, 2006 3:06 pm    Post subject: fiberglass panel Reply with quote
brinker,
you may want to consider cutting a good portion of your fiberglass panel out and replacing it with .062 alum. make a left panel and a right panel. now the panels are removeable for access to the instruments. will take a little engineering [ that is a figure of speech only!] to get the strength around the edges to mount the alum. to but it worked great for me on my dakota hawk. now instead of a one piece permanent panel i can open up either panel in 2 minutes. there is more than a little to be said for being able to make your panel with a drill press and work on it lying on your workbench.
bob noffs... i just cut out the instrument holes today, tomorrow the toggle switches and the square holes!
brinker(at)cox-internet.c
PostPosted: Wed Jan 04, 2006 3:34 pm    Post subject: fiberglass panel Reply with quote
Thanks for the idea I'll definately give it some thought.
