JAPhillipsGA(at)aol.com Guest
Posted: Wed Jun 20, 2007 8:44 am Post subject: Jab 3300 Fuel Pump |
Dear Jab 3300 Flyers, show of hands. How many use the elec fuel pump on run up ? How many use the elec fuel pump on take off ? And again in the pattern for landing ? Hope to hear from you guys and best regards, Bill of Georgia
See what's free at http://www.aol.com. [quote][b]
rpf(at)wi.rr.com Guest
Posted: Wed Jun 20, 2007 10:15 am Post subject: Jab 3300 Fuel Pump |
Hi Bill,
I fly a 601xl and turn my elec. fuel pump on for about 10 seconds before starting the engine. Turn the pump off start the engine and it's not used again during flight or landing. This is what Pete, at Jabiru USA, said they do.
Randy
tonyplane(at)bellsouth.ne Guest
Posted: Wed Jun 20, 2007 10:29 am Post subject: Jab 3300 Fuel Pump |
Very seldom* use electric fuel pump on take off although I put it in my checklist to use on take off and landing. Same for Landing. (It causes my fuel flow turbine to read too high - I placed the fuel flow turbine too close to the elec pump.)
I do use the electric pump for 10 seconds before start. I do not use it for run-up
*If the runway is short, I DO use the electric pump for take off and landing.
Tony Graziano
XL/Jab3300; N493TG 252 fun hrs with the XL- and never had a carb or start problem or concern.
Subject: Jab 3300 Fuel Pump From: JAPhillipsGA(at)aol.com ([email]JAPhillipsGA(at)aol.com?subject=Re:%20Jab%203300%20Fuel%20Pump&replyto=d1a.cda2a31.33aab319(at)aol.com[/email]) Date: Wed Jun 20 - 9:44 AM
| Quote: | | Quote: | Dear Jab 3300 Flyers, show of hands. How many use the elec fuel pump on run
| [quote][b]
rick.tedford(at)sympatico Guest
Posted: Wed Jun 20, 2007 12:41 pm Post subject: Jab 3300 Fuel Pump |
Hello Bill : The only time I use the electric pump is to prime the system before start up . I don't think putting the pump into the system before the gascolator is good as it would pressurise same and those can leak quite easily . Naturally it is there as a back up in the event the pump on the engine fails .
Best Regards
Rick Tedford
601XL , Jab 3300
C-FRTT , 250 hours
zodiacjeff(at)msn.com Guest
Posted: Wed Jun 20, 2007 12:56 pm Post subject: Jab 3300 Fuel Pump |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> >I fly a 601xl and turn my elec. fuel pump on for about 10 seconds before
| Quote: | starting the engine. Turn the pump off start the engine and it's not
said they do.
Ditto - with the addition that here it's an HDS with wing tanks feeding into a common gascolator in front of spar and then onto header tank via Facet. This is the old Brent Battles' design from ancient days.
I use the Facet between the firewall gascolator (in series) and the mechanical Jab pump only to prime engine.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Jun 20, 2007 4:46 pm Post subject: Re: Jab 3300 Fuel Pump |
Regarding the comment: "This is what Pete, at Jabiru USA, said they do. "
Was Pete talking about a Jabiru 3300 in a Jabiru aircraft (high wing) or a low wing? Big difference!
As I recall, SOP in most low wing aircraft is electric fuel pump on before engine start thru takeoff and climb to a safe altitude - also when switching tanks and when landing. There is a point in the pre takeoff checklist where the electric pump is switched off to see if the engine keeps running.
If your engine driven fuel pump failed on takeoff and your electric pump was not on, bad things could happen very quickly. Unless someone can give me a good reason to do otherwise, my pump will be on.
Note: When choosing a fuel pump for the Jab remember that you don't want the fuel pressure to get too high (around 3-3.5 psi max.) The pump that comes with the Zenith Kit puts out more than that so I replaced it with a Facet 40104.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Wed Jun 20, 2007 6:26 pm Post subject: Jab 3300 Fuel Pump |
He said it was on a low wing.
Fine, do what you want. I just stated what I do.
Tim Juhl
Posted: Thu Jun 21, 2007 6:33 am Post subject: Re: Jab 3300 Fuel Pump |
Randy,
I wasn't being critical. I've met Pete a few times and took the "Jab install in a Zodiac" class at his place in Shelbyville. He never commented about when to use the fuel pump and in retrospect I should have asked. He did warn about using fuel pumps that put out too much pressure. Your comment is very helpful in that I am going to find out from Pete what his logic is behind the procedure he recommends.
The low wing Pete sells is the Lightning.... I can't tell you how it's fuel system design compares to the XL.
In my 32 years of flying I've had 3 in-flight engine emergencies that required immediate landings. Fortunately each one was at altitude and an airport was nearby. My biggest fear would be power loss shortly after liftoff so you can understand my concern. All the other aircraft I've owned have been high wing and didn't even have a electric fuel pump so the XL will be something new for me. My experience with low wing aircraft is restricted to aircraft I have trained in and flown while giving flight instruction, mostly Piper and Beech products.
CFII
Champ L16A flying
Posted: Thu Jun 21, 2007 1:18 pm Post subject: Jab 3300 Fuel Pump |
Sorry for being short with you Tim, bad day.
Prior the my 601xl I built a Skyranger with a 912s. It was a high wing but
the fuel tank was located behind the seats essentially making the fuel run
up to the engines mechanical pump. The fuel system was similar to the xl
with a elec. pump between the fuel tank and the mechanical pump. As with
the xl I used the electric pump just prior to start up and the mechanical
pump after that. I had almost 400 hours on that plane and never had a fuel
delivery problem.
Randy
japhillipsga(at)aol.com Guest
Posted: Tue Jun 26, 2007 8:28 am Post subject: Jab 3300 Fuel Pump |
Randy, that's the same thing he told me, thanks, Bill
Tony, I do the same, thanks for the info. Bill
Posted: Tue Jun 26, 2007 8:29 am Post subject: Jab 3300 Fuel Pump |
Rick, I do the same thing for the same reason, Thanks for the info, Bill
