Kitfox-List:
wingsdown(at)verizon.net
PostPosted: Mon Jun 25, 2007 7:24 am    Post subject: Kitfox-List: Reply with quote
Barry,
Sounds like your up to the task. I would dissemble both carbs and inspect the needle seats, slides and metering rods for any unusual wear or nicks. Re-set float bowl height and test levels. Also if you have a fuel regulator I might think it suspect. If it intermitted supplies to much pressure you can run rich enough long enough to foul the plugs. If it runs fine with new plugs and then goes foul that would be my guess.
Rick
barry(at)pgtc.com
PostPosted: Mon Jun 25, 2007 9:11 am    Post subject: Kitfox-List: Reply with quote
Thanks Rick, I'm sending the carbs to Lockwood for rebuild.
Barry
Float Flyr
PostPosted: Mon Jun 25, 2007 1:59 pm    Post subject: Kitfox-List: Reply with quote
I would also consider a differential compression test. If the engine mount was damaged it is also possible the block or the heads may have taken a bit of punishment. Soot normally means over rich but can also be low compression.
[img]cid:804275421(at)25062007-233A[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  306 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
