Article on flutter, now attached
willie.harrison(at)tinyon
PostPosted: Mon Jun 25, 2007 6:25 am    Post subject: Article on flutter, now attached Reply with quote
Dear All
Many thanks to Martin Le Poidevin at Flyer Magazine for letting us
distribute the article on flutter, which is now attached. It is PDF
and may be easier to read if you print it.
The link to their website incidentally is: www.flyer.co.uk
Willie Harrison
FLYER_flutter.pdf
 Filename:  FLYER_flutter.pdf
 Filesize:  162.61 KB
 Downloaded:  553 Time(s)
Gilles.Thesee(at)ac-greno
PostPosted: Mon Jun 25, 2007 8:11 am    Post subject: Article on flutter, now attached Reply with quote
William and all,
Thanks for this very knowledgeable article.
By the way, balancing control surfaces directly instead of using a bob
weight on a balance arm is considered safer when practicable, especially
if the weight is evenly distributed spanwise.
I'm aware of at least two aerobatics airplanes that went down due to
aileron balance arm attachment failure followed by explosive flutter. In
one case the crew was able to bail out.
Has anyone mentioned balancing each tailplane directly with lead in the
leading edge? This would eliminate any possible slop on the balance arm
attachment points and reduce wear an tear on the torque tube.
FWIW,
Best regards,
Gilles,
http://contrails.free.fr
ami(at)mcfadyean.freeserv
PostPosted: Mon Jun 25, 2007 12:40 pm    Post subject: Article on flutter, now attached Reply with quote
So, does the Liberty use the same system as the Europa?
Duncan McF.
PostPosted: Mon Jun 25, 2007 1:09 pm    Post subject: Article on flutter, now attached Reply with quote
Not forgetting that I=mr2, counterbalance weights in the tailplane leadng
edge, apart from being much heavier would have much less inertia, offering a
lower amount of resistance to flutter and/or its initiation.
Duncan Mcf.
topglock(at)cox.net
PostPosted: Mon Jun 25, 2007 1:25 pm    Post subject: Article on flutter, now attached Reply with quote
It would be interesting to know just how much lead would be needed to
balance the tailplanes in this way...
Jeff - Baby Blue
299 hours
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
William and all,
especially if the weight is evenly distributed spanwise.
In one case the crew was able to bail out.
the leading edge? This would eliminate any possible slop on the
balance arm attachment points and reduce wear an tear on the torque tube.
FWIW,
Best regards,
PostPosted: Mon Jun 25, 2007 1:37 pm    Post subject: Article on flutter, now attached Reply with quote
Duncan & Ami McFadyean a écrit :
<ami(at)mcfadyean.freeserve.co.uk>
leadng edge, apart from being much heavier would have much less
inertia, offering a lower amount of resistance to flutter and/or its
initiation.
Duncan,
The leading edge balance weight is something widespread in aviation.
Concerning weight, some messages seem to state that some Europas do
carry weight in the tail.
Defeating flutter necessitates a complex study, but mass balancing has
something to do with the POSITION of the CG of the control surface. It
is considered that one should aim at a forward or at least neutral CG
position with regard to the control hinge.
A lightweight construction aft of the hinge point is key, and painting
and hardware are best carefully studied to avoid adding weight aft of
the hinge.
The problem with mass balance arms (which are also used), is localized
wear and tear allowing slop to develop. Any slop encourages flutter.
Of course flutter also has to do with torsional and flexural(?)
properties of the structure.
Darrol Stinton's Design of the aeroplane could be a good starting point
for further insight.
FWIW,
Best regards,
Gilles
DuaneFamly(at)aol.com
PostPosted: Mon Jun 25, 2007 8:20 pm    Post subject: Article on flutter, now attached Reply with quote
Thoughts and questions for those that know,
I have been reading with great interest.....and concern......this flutter thread. Please correct me if I'm wrong, but isn't the flutter the result of the total slop anywhere in between the mass balance weight and the tailplane? The more slop the more up and down travel distance the tailplane will be able to move. I doubt if the mass balance weight is fluttering during this event.
Now if the weight was an integral part of the tailplane, then one could not flutter without the other. And since the weight would be further back, the fuselage CofG could be maintained with less total weight.
Question: Does the frequency of the flutter of a particular plane increase and decrease with a change of airspeed? What is the failure mechanism caused by flutter? Does the part that flutters destroy itself?
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
See what's free at AOL.com.
